Unwanted reactivating marked tip changes
  • Unwanted reactivating marked tip changes
    When taking a program I've written for a full layout, and marking out certain sections to only perform a portion of the measurements, some or all of my marked tip changes will unmark themselves when I execute the program.
    I checked to make sure it wasn't connected to a feature that was set to automatically assign a tip change, and I've recreated some, but to no avail. It still happens. I know there's a way to disable them as I've done it in the past and it's kept them marked.
    Can someone help?
    Thank you!
    I'm pretty sure F5 checkbox off "reset global settings when branching" will then skip unmarked probe tip rotations.
    Instead of using mark/unmark, you can use if_goto syntax with a label to jump around the routine.
      That worked like a charm. Thanks louisd!
