slot view.jpg Hello I hope someone could help me with this.I'm measuring slots and I'm trying to use mmc from slot size for TP calculation.Slot size is an intersection of a plane and a cylinder where 4 points are on the bottom .What type of feature would I use to achive that?pnt_pl_1,2<3<4 create bottom plane then I tried measuring cylinder but what would I use to intersect those two features.? SLOT SIZE.jpg
Slot size construction
by gszpotI have a slot, 3mm" wide 16mm" deep. Customer wants to know what size pin will fit in using the CMM. The problem is I can only measure the...
12-07-2016, 03:17 PM -
I'm new to the PC-DMIS software so this maybe easy to answer for someone. I have a measured slot on a measured plane, and I would like to project this...
06-30-2011, 12:46 PM -
by swisk212Print interpretation is AMSE Y14.5M 1994. The attached is a sketch (sorry for hand drawn symmetry call out). I am holding the cylinder vertically using...
08-24-2019, 12:07 PM -
by seppleyHi all!
Below is a sketch that represents a measurment that i need to take from one of our prints. They won't let me post the actual print...-
08-05-2013, 09:02 AM -
by OhmasI'm having kind of headache with this.
It's a cylinder with 8 slots at the end, positioned to Datum B (outer cylinder) by 0,05, and relative to...-
11-21-2016, 04:40 AM -
