How does PCD use the bonus and datum shift? I had a part that's right according to the report but the engineer think it's a mistake. I want to be able to explain this to her so I can put this to bed!!!!
How Does the Demon Use Bonus and Datum Shift When Reporting?
Datum shift (from (M) on datums) is used for (larger) "wiggling" room when fitting to datums.
Bonus (from (M) on features) is used to enlarge the tolerance zone depending on the features size and tolerance.PC-DMIS CAD++ 2o22.1 SP2
- Likes 1
Just FYI, you may already know this but I'll say it anyway...If a part is in spec without using a datum modifier, then it will be in spec with, 100% of the time. In my experience they're usually more trouble than they're worth.
Darrollh make sure your Datum structure makes sense also. Or you could end up with sh_it like this. because of pi_ss poor engineering.
maxresdefault[1].jpg(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
Arguing with an engineer is a waste of time, even if you show them proof. They don't believe you, because they THINK they don't make mistakes. Ask them the formula for Position.
Here you might have better luck with this.
How about this, Tell Her, I just showed you its BAD, How about you go show me on the Surface Table, Lay It out, and show me it's good!Last edited by KIRBSTER269; 06-14-2019, 12:33 PM.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
Do you have a check fixture to place the part on, clamp it, pin the feature that is in question? I try to use a check fixture for part measurement as much as possible. If PCD reports something out, it should be the same on the fixture. There are many times where the positional pin will scrape the edge of the measured feature, that can be the edge of acc. or reject with PCD.
Ok, so it sounds like a simple question, do I get MMC/LMC bonus off a datum feature?
For example [Dia .005-M][A-M][B]
normal logic would...-
10-23-2013, 05:25 AM -
by dtmtimHello,
We rarely see LMC called out on a drawing and I have never had one with LMC on a datum and a feature. My customer believes that...-
12-05-2014, 08:31 AM -
by GREGFHELLO i'M RUNNING A PROGRAM THAT HAS POSITION TO WITH MMC ON FEATURE CHECKED AND MMC ON DATUM BE .XACT MEASURE DOESN'T ADD BONUS FROM DATUM.DOES ANYONE...
09-28-2017, 03:32 PM -
by Fasteddie0I apologize if there is a post definitively explaining this but I want through a few and couldn't find the answer. I have a part that datums A and B have...
12-19-2017, 02:33 PM -
by BravePCDMISDoes anyone have a problem with Datum Shifts in PCDMIS 2013 MR1? Sometimes there will be shifts/rotations in the profiles then sometimes not. The program...
02-21-2015, 10:07 AM -
