2018 r2 sp7
  • 2018 r2 sp7
    here :
    or here (#460 !):
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...18_R2/SP7/x64/
    Release Notes - 2018 R2
    SP7
    • PCD-100898 - Fixed an issue where specific manual measured contact slot
    features did not completely execute.
    • PCD-144409 - Fixed an issue where the incorrect vector appeared when a
    second freeform plane was created.
    • PCD-149319 - Fixed an issue where the Text and CAD (TEXTANDCAD.RTP)
    template was broken because the SIMUL_LABEL.LBL file was missing from
    the installer.
    • PCD-152485 - Fixed an issue where the Optimize Path Workflow dialog box
    stopped responding.
    • PCD-152952 - Fixed an issue where an exclusion plane could not be scanned
    if the measurement routine already contained laser auto features.
    • PCD-153254 - Fixed an issue where 4-axis scanning was not available for the
    Adaptive Plane Circle Scan strategy for the Plane Auto Feature.
    • PCD-157075 - Fixed a crash that occurred when the Status window was
    enlarged greater than the Graphic Display window with a Pointcloud Surface
    Colormap scale.
    • PCD-158695 - Fixed an issue that prevented feature items from appearing in
    the feature list of the XactMeasure GD&T dialog box.
    • PCD-160232 - Fixed an accuracy issue that occurred when a rotary table was
    switched on with Technology Server 1.5 on Leitz CMMs with a Leitz B5
    controller.
    • PCD-160312 - Fixed an issue that occurred when you created linear open
    scans with the auto-dimension setting enabled.
    • PCD-160827 - Fixed a crash that occurred when you loaded and executed a
    measurement routine with DIMINFO commands inside a loop.
    • PCD-162047 - Fixed an issue that affected bonus to appear when the input
    features had different vectors.
    • PCD-162715 - Fixed an issue that occurred when you selected ON from the
    Report textual analysis list on the Reporting tab in the XactMeasure GD&T
    dialog box. This selection always used to display zero bonus values in the
    report.
    • PCD-163223 - Fixed an issue where the setup default settings of the I++ Client
    for Technology Server 1.5 on CMMs with a Leitz B5 controller were incorrect.
    The change is described in the MIIM Help documentation.
    • PCD-163823 - Fixed an issue where the Done button on the jog box did not
    work when both arms executed a manual feature in a dual-arm measurement
    routine.
    • PCD-165295 - Updated to the latest available CMS Toolkit 7.40 that improves
    the calibration process.
    • PCD-165488 - Fixed an issue where licensing registry searches didn't properly
    check whether the HASP license existed or not.
    • PCD-165636 - Fixed an issue where the outlier filter didn't always properly
    filter Vision Line features if those features were in a subroutine.
    • PCD-166030 - Corrected an issue when you used the Leica AT901 tracker
    where the incorrect measurement profile was set and hits were not taken
    with the reflector or T-Probe.
    I think I got one fixed from the 2018 megathread:
    Slooooooooooooooooooooooowly...
    PC-DMIS CAD++ 2o23.1
      Here we often say :
      "Gently in the morning, not too fast in the afternoon"...
