we are using PCDMIS for CMM and have direct Catia interface for our machine. my problem is the latest model i brought in seems too large for PCDMIS to handle so the graphics have slowed down to almost nothing. is there a way to reduce the model size either in catia or pcdmis to help with my graphics? right now it is unusable.
pcdmis model size
You can turn up the tessellation value in Edit> Graphics Display Window> Open GL. As you turn up the value, the model will become more faceted and won't look as good, but it will require less from your computer
- Likes 1
As mentioned above the tessellation value can have a large effect. Below shows the sizes of a 28M NX file once imported.
Tessellation value and pc-dmis cad size
1 17M
.5 21M
.1 59M
.01 406M
As you can see the size can get very large. Below is my graphics info. [email protected]
graphics.jpgLast edited by rjurca; 06-14-2019, 02:49 PM.
by larandeauwhen opening models ,catia 5,steps or iges,somtimes the dia look like hexagons.is the anyway to adjust the models
05-24-2011, 11:51 AM -
Hi Techs;
Maybe you know???
I am offline programming in 4.1, and am having a problem with the graphics fitting the screen....-
10-08-2012, 11:35 AM -
by David WedelHeres the deal I Imported a solid model and programmed off of it lets say a yr ago and just today opened it up to check part and noticed the model is...
05-04-2010, 01:19 PM -
by Jonde1Can anybody tell me if you are able to toggle the swift fix CAD model off/on in PC-dmis? I have tried using a clip plane but it doesn't effect the swift...
11-29-2016, 06:38 AM -
by xharpbobHello, I'm programming offline and have imported a CAD file, taken hits to create manual and DCC alignments. Solid Model graphic suddenly changed to a...
07-15-2011, 09:41 AM -
