I have a part family that I am creating a variable program for, and am running into issues with the values not updating in the auto features. I've assigned variables at the top of the program, and then use those variables in Auto Circles. The problem I have is that when I type in a new value for the variable, the hits in the auto features don't update. Example. I assign ID=1, and then set the diameter on my auto circle to "ID". The first time through it runs fine for that part. Then when I change it to ID=2, and rerun the program, it tries to measure a 1" ID still. Is there a setting to force the hits to be updated every time a program is ran? I did this same thing 10-15 years ago and have programs that have been running flawlessly ever since, but can't seem to get it to work now.
Variable Auto Features not updating
Where are you inserting the variable names at:
Code:CIR1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<v1.x,v1.y,v1.z>,<v1.i,v1.j,v1.k>,v1.d,0 [COLOR=#FF0000]<< here?[/COLOR] ACTL/<1,2,3>,<0,0,1>,1,0 TARG/<v1.x,v1.y,v1.z>,<v1.i,v1.j,v1.k> [COLOR=#FF0000]<< and here?[/COLOR] START ANG=0,END ANG=360 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=4,DEPTH=-0.1,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0.1 AVOIDANCE MOVE=NO,DISTANCE=0.2 FIND HOLE=NOCENTER,ONERROR=NO,READ POS=NO SHOW HITS=NO
Global 7-10-7 DC800S
I just tried it on a simple routine, using 2012MR1, and it works fine offline.
v5 at 1.875
Code:ASSIGN/V5=1.875 CIR2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<0,0,0.005>,<0,0,-1>,V5 ACTL/<0,0,0.005>,<0,0,-1>,1.875 TARG/<0,0,0.005>,<0,0,-1> START ANG=0,END ANG=360 ANGLE VEC=<0,1,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=5,DEPTH=0,PITCH=0 SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=YES HIT/BASIC,<0,0.9375,0.005>,<0,-1,0>,<0,0.9375,0.005> HIT/BASIC,<0.89162,0.2897,0.005>,<-0.9510565,-0.309017,0>,<0.89162,0.2897,0.005> HIT/BASIC,<0.55105,-0.75845,0.005>,<-0.5877853,0.809017,0>,<0.55105,-0.75845,0.005> HIT/BASIC,<-0.55105,-0.75845,0.005>,<0.5877853,0.809017,0>,<-0.55105,-0.75845,0.005> HIT/BASIC,<-0.89162,0.2897,0.005>,<0.9510565,-0.309017,0>,<-0.89162,0.2897,0.005> ENDMEAS/
Code:ASSIGN/V5=0.875 CIR2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<0,0,0.005>,<0,0,-1>,V5 ACTL/<0,0,0.005>,<0,0,-1>,0.875 TARG/<0,0,0.005>,<0,0,-1> START ANG=0,END ANG=360 ANGLE VEC=<0,1,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=5,DEPTH=0,PITCH=0 SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=YES HIT/BASIC,<0,0.4375,0.005>,<0,-1,0>,<0,0.4375,0.005> HIT/BASIC,<0.41609,0.13519,0.005>,<-0.9510565,-0.309017,0>,<0.41609,0.13519,0.005> HIT/BASIC,<0.25716,-0.35394,0.005>,<-0.5877853,0.809017,0>,<0.25716,-0.35394,0.005> HIT/BASIC,<-0.25716,-0.35394,0.005>,<0.5877853,0.809017,0>,<-0.25716,-0.35394,0.005> HIT/BASIC,<-0.41609,0.13519,0.005>,<0.9510565,-0.309017,0>,<-0.41609,0.13519,0.005> ENDMEAS/
Is it a comment and not an assignment? if it's an input comment, you need to use ".input" at the end of the comment name (generally starts with C1) so C1.Input would produce the value for C1.
Here is the code for variable assignment:
Code:ASSIGN/V10=1.44 ASSIGN/V11=0 ASSIGN/V15=4.205 ASSIGN/V20=5.04 ASSIGN/V30=4.6685 ASSIGN/V50=4.47 ASSIGN/V60=.4355 ASSIGN/V70=.692 ASSIGN/V80=.145 ASSIGN/V90=.05 ASSIGN/V100=20
Code:ID =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<V11,V11,V11>,<0,0,1>,V15 ACTL/<0,0,0>,<0,0,1>,4.205 TARG/<V11,V11,V11>,<0,0,1> START ANG=0,END ANG=360 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=YES VOID DETECTION=NO REMEASURE=NO SURFACE=THEO_THICKNESS,0 MEASURE MODE=NOMINALS RMEAS=NONE,NONE,NONE CIRCULAR MOVES=CIRCULAR GRAPHICAL ANALYSIS=NO FEATURE LOCATOR=NO,NO,"" SHOW CONTACT PARAMETERS=YES NUMHITS=4,DEPTH=0.125,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=YES HIT/BASIC,<2.1025,0.003,-0.125>,<-0.999999,-0.0014443,0>,<2.1025,0.003,-0.125> HIT/BASIC,<-0.003,2.1025,-0.125>,<0.0014443,-0.999999,0>,<-0.003,2.1025,-0.125> HIT/BASIC,<-2.1025,-0.003,-0.125>,<0.999999,0.0014443,0>,<-2.1025,-0.003,-0.125> HIT/BASIC,<0.003,-2.1025,-0.125>,<-0.0014443,0.999999,0>,<0.003,-2.1025,-0.125> ENDMEAS/
2 Brown & Sharpe ONE CMM's
2 454 SF CMM's
Brown & Sharpe MicroXcel Pfx
Brown & Sharpe Profile 50
PC-Dmis vs 2012
The variable are all assignments, and are not passed in from a comment. When I hover over the variable in the auto feature, it returns the correct value, it just doesn't go to the correct points. If I edit something such as the number of hits in the auto feature, it then recalculates the hits, and everything works fine. But I have to force a recalculation of the hits after changing the variable value, otherwise it will just run at whatever the original value was.2 Brown & Sharpe ONE CMM's
2 454 SF CMM's
PC-Dmis vs 2012
What they mean is that the variables for the assignments should be entered by a input comment at the beginning of the program. Comment asks whey part are you going to run? and depending on what is entered, it fills in the assignments for your variables instead editing the program for every part change.
Originally posted by metalquest1 View PostHere is the code for variable assignment:
Yep that should work.
Try this:
Code:ASSIGN/V1=54 COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, "This is the value of V1: " + V1
PcDmis 2015.1 SP10 CAD++
so either your feature is glitching out some way, or you have something else in your code, contributing to the issue that we haven't seen... loops? goto label jumps? are all 6 degrees of freedom controlled via alignment and in correct order (Level/Rotate/Origin)? current workplane is in Z Axis?
by tclementsIs there anyone out here that can explain how the hits are generated in auto circle. I've written a program using assignments for the diameter of the...
02-19-2007, 11:21 AM -
by BKulpaHas anyone ever tried to use a variable assignment to change the distance of the avoidance move in an autofeature circle?
Seems like it should work...-
01-19-2017, 12:30 PM -
by David WedelAnyone have a code or an idea of a code to insert after a circle that would maximize the diameter without manually doing it. Trying to avoid stopping...
04-15-2013, 12:09 PM -
by ClayOgreI have four different parts which are made from a single casting. The only difference is the location of a single hole. At the beginning of the program...
11-18-2014, 08:35 AM -
I have 3 circles taking points trying to avoid "barbs".... If the operator notices the probe hit the barbs he says yes..... there for goto_...
05-06-2016, 01:36 PM -
