Needing some clarification, I'm saying that the profile in the picture is for form and location due to the location constraints from datum A & B, my counterpart is saying form only. The two dimensions that locate this feature from the datum's are boxed (not shown). See attached .jpg below and let me know who is correct. Thank you in advance.
Profile
KIRBSTER269 I'm not sure what you talking about if the callouts then you don't get that option for form and location.sigpic
As You can see in my example my Max is +.0003 to much material but still in tolerance of my +.010 and my lowest point in my scan, not enough material, was -.0014 but still in tolerance of my -.010 tolerance. The MEAS is just my lowest and highest points added together not really tell you anything there.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
- 3 likes
I found it with your help, thanks. But one more question Using legacy callouts the results of my profile comes from the alignment which is shown on the .jpg on the 1st comment. Datum A & B which then throws my profile form and location out of tolerance. I could use custom report to call out my profile only to datum A shown by building a FCF but I don't think you can use legacy along with custom reporing (that you use KIRBSTER269).sigpic
I am not sure exactly what you're asking, but Legacy is based off of how you aligned your part, you know your 321 alignment, so say you level to let's say PLN2, and it isn't actually Datum A, then that's what legacy is considering form and location, where when you use Xact, it starts building a ghost Trihedron and if you put your cursor in the Editor on one of your Xact callouts and look to your CAD model you'll see that second Trihedron appear, unless of course it is an identical alignment to your 321 alignment. You may already understand this part. I'm just not sure what your asking. The reason why I used the Customized was only because of this one particular blue print and the way they called it out. This just happened to be one unusual callout. This isn't normal
When I call out the scan it uses the Z level (Datum B) which is a plane .625 above the center of my radius and it also uses inside diameter X & Y for side to side location (Datum A). So if I didn't want to use the Z in my Form and Location callout how do you go about that. I'm using the legacy style callouts. Just want to use side to side X & Y and not the Z in my calculations. How hope this is better to understand.
I think I was saying could not use the FCF because I use (Use Text Mode Dimension Reporting)
Unchecked (Use Text Mode Dimension Reporting)
Unchecked (Use Legacy Dimensions) and created my FCF and all looks good except the Datum shift Box below the callout anyway to remove that. See below.
If you put your mouse right on that label and right click on it, you can hide the datum Shift. I don't think it sticks everytime you run it so you might have to do it every time.
Before
After
Actually this Pops up when you do that so you can eliminate it if you want.
Capture.JPG(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
- 1 like
by nitpickergot a difference of opinion with our engineers that has been going on for a couple weeks now. They are calling out form and tolerance of a ripple profile...
09-09-2019, 10:18 PM -
by RSNICKERDoes anybody know if the 4.2 software can measure a double profile callout.
I have a profile of two radii with a tolerance of 4 to datum B and...-
06-18-2009, 01:53 PM -
by jay RHey everybody, it is a great day for me today and maybe not so much for you all!! I finally have internet access in my inspection lab, so posting questions...
08-25-2006, 02:39 PM -
by NguyenI have to measure the profile of 825 nubs with respect to a datum plane. I pick a point on top of each nub then create a best fit plane go through all...
02-15-2008, 06:12 PM -
by Mike_BOk, same part I have been programming for a while now. I understand the difference in legacy and xact, I like legacy though.
I have it aligned,...-
02-24-2015, 05:05 PM -
