Labeling individual points on an auto plane
  • Labeling individual points on an auto plane
    We use PC DMIS 2015 and I was wondering if there was a way to label each individual point of an auto plane in the graphic display window? The particular program I am wanting to do this on does not have a CAD model.
    Nope BUT using Auto Vector points to construct a Plane... you could:
    F5 -> ID Setup -> Labels for: Features -> Type: Points -> Starting Letters: Type what you want here -> Apply -> YES ->OK. Change as many times as you want and as long as you don't click "Defaults" it should only affect the part routine you're currently working on.
    PcDmis 2015.1 SP10 CAD++
    Global 7-10-7 DC800S
      Yes.
      PLN1       =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,OUTLINE,LEAST_SQR
                  THEO/<0,0,0>,<0,0,1>
                  ACTL/<0,0,0>,<0,0,1>
                  TARG/<0,0,0>,<0,0,1>
                  ANGLE VEC=<1,0,0>,RADIAL
                  SHOW FEATURE PARAMETERS=NO
                  SHOW CONTACT PARAMETERS=YES
                    NUMHITS=12,NUMRINGS=1
                    SPACER=100
                    AVOIDANCE MOVE=NO,DISTANCE=10
                  SHOW HITS=NO
      V1         =LOOP/START,ID=NO,NUMBER=PLN1.NUMHITS,START=1,SKIP=,
                    OFFSET:XAXIS=0,YAXIS=0,ZAXIS=0,ANGLE=0
                    ASSIGN/FZNAME=CONCAT("DAT_A_POINT",STR(V1))
      FZNAME       =GENERIC/POINT,DEPENDENT,CARTESIAN,$
                    NOM/XYZ,<PLN1.HIT[V1].TX,PLN1.HIT[V1].TY,PLN1.HIT[V1].TZ>,$
                    MEAS/XYZ,<PLN1.HIT[V1].X,PLN1.HIT[V1].Y,PLN1.HIT[V1].Z>,$
                    NOM/IJK,<0,0,1>,$
                    MEAS/IJK,<0,0,1>
                  LOOP/END
      • Kp61dude!
        Kp61dude! commented
        Yep, this is definitely a better route especially after the fact. There's also a "TO_POINTS.EXE" somewhere here on the forum that comes to mind.
      • dopalicious
        dopalicious commented
        Awesome! Thank you
      One trick could be to create the autoplane as you want it, copy it to a new feature, F9 the copied feature and break it out to vectorpoints. If the last step doesn't work, simply use the "To points" script to break it out to points. The RandomJerk way might be smarter though, as that method doesn't create features that will be measured in a program.
      PC-DMIS CAD++ 2o23.1
        Insert -> Report command -> Point Info...
        No need to do any extra work, construction or other contortion.
        • NinjaBadger
          NinjaBadger commented
          Winner winner chicken dinner!
        Thank you all. I love this forum lol
