I write programs using a part that's been machined. Nothing's ever perfect, and occasionally it's not even in tolerance when it's been submitted for 1st piece...
I don't have CAD access. It's a Global Performance with 2018 R2.
Every now and then, when I have a (circular or cylindrical) scan, I'll program it in (put the move point in, located over the center of the hole, maybe .1 above the top surface, and insert the appropriate scan, plugging in the proper coordinates (according to print), it'll scan it, and what shows up on the graphic display is an arc with the two ends connected. Kind of a half moon kinda deal.
What's the deal? Is it that the hole is so far out of location that it's not scanning the entire circumference? If I adjusted my prehit/retract, might that solve the issue?
