dims not send to statistic
  • dims not send to statistic
    I'm using PCDMIS 2018 R2,I use 'size" tolerance for most dias, in utility box I have selected option to send dims to report and statistic ("both"), dims show up on the report but are not send to statistic. I have searched for size dims in .xml file and they are not there as well in DataPgage+ (I use 5.0). Any suggestion?
    ask tech support / file an issue. Maybe the size command was added but the stats supporting output was not.
      There is a bug report [PCD-141508 - "Size command with standard ASME does not get reported in xml results file"], but it is marked as "Fixed in 2018 R2", so I'm not sure it's the same as you see. The corresponding problem in Excel export is fixed in 2019 R1.
        Does it report in ISO?
        PC-DMIS CAD++ 2o22.1 SP2
