Wrong position of CAD with machine loaded
  • Wrong position of CAD with machine loaded
    Dears,
    I tried to find solution, but found nothing. When I have machine loaded, import CAD, position it and align the measured part, the CAD and measured features are in different position in graphic window, than in reality (In DCC Machines probes, where it should).
    When I do the same, but I am not loading the machine, the CAD is in correct position in the graphic window.
    Kindly asking, what am I missing.
    Thank you
    PCDMIS 2019 R1, Online
    I usually bring in the cad transform it then load the machine. Is that how you do it?
    Darroll
    2018R2
      HI Darroll,
      Thanks for reply, did this way - Machine, CAD, Transform
      Tried it your way, but problem remains.
        We have the same issue on a couple of programs here. I've found that it depends on where your cursor is in the program. If it's before the alignment, there's no relation between the two (CAD graphic and program). If the cursor is after the alignment, the wireframe overlays the CAD graphic, and all is right with the world...
          Hi Filip,
          It absolutely depends on the cursor position in the edit window when dealing with virtual machine and alignment functionalities. I would recommend this way.
          • Import the Machine Model.
          • Then CAD.
          • Do Auto position from the F5 dialog to position the CAD correctly on the virtual CMM machine.
          • Then go with Manual and DCC alignment.
          • Then proceed with your measurements.
          I have just tested before posting this. It works fine.
          If the issue still persists at your end, I would like to take a look at your program code for further details.
          Regards,
          Krishna Chaitanya Velisetty
          Metrology Software Applications Specialist,
          Hexagon Manufacturing Intelligence.
          • Numbers Game
            Machine CAD=part
            by Numbers Game
            I occasionally insert the machine into the graphics window for the sake of visualising how my setup will look. However, none of my parts have regular...
            09-09-2016, 11:19 AM
          • paulrbtd
            Cad sync
            by paulrbtd
            I have trouble getting the cad files to sync to the measurements.
            Working with automotive parts, step files.
            Any input ????
            Thanks...
            01-22-2010, 06:58 AM
          • Brucifer
            Multiple machine to CAD orientations
            by Brucifer
            When I import a CAD model, I change the machine axes to match the CAD.
            Is it possible to change this in the middle of a program?
            For example,...
            03-10-2010, 06:05 PM
          • ncsteinb
            Where is my CAD??
            by ncsteinb
            I've gone through most of the topics on missing CAD already, and cannot seem to find a solution. I've had a working program for a while now, and after...
            11-16-2021, 09:19 AM
          • luciano
            Cad position
            by luciano
            I have dificulties to put my CAD model on the plate , when I import CAD model and I have arleady teo CAD file on PC_DMIS , I try to put in position but...
            05-13-2013, 08:23 AM
