Evening all,
Quick question, when I form a scan along a surface and convert to points it seems that the points are not going fully around tight rads for example and seems to jump the rad
I construct the scan by selecting the surfaces on the cad as normal and set nominal method to find nominals and exec control to defined, make sure cad comp is slected and boundary type is plane's. After all this I find the scan misses certain hits along the surfaces when you convert to points. Any ideas. Depending on where you set your 1, D and 2 points, the points can be missed between the points 1 and 2.?
Thnaks.
Thnaks.
