Hi all,
I've been running a dual arm DEA Bravo with infinite wrists and 4 probe heads for each arm. I have completed the entire calibration procedure from scratch several times, and gotten very good results. The problem I have is that the arm to arm relationship in the Y axis seems to drift over time. I have a calibration program that calibrates the probe heads at several angles and finishes up with an origin only arm to arm calibration, and my results are always excellent. But I also have a validation program that sets the common sphere as the origin and measures it using both arms and all 4 probes at various angles. I ran it the other day and I see a difference in Y of 0.3 mm between the arms that is independent of the probe head and the angle. The only way I know to get rid of it is to blow out my .DAT files and complete the entire calibration procedure from scratch. I did this the other day and presto! Arm to arm relationship is good again! My question is why doesn't the normal calibration procedure correct for the shift, and why are my results always show good when there is a shift present?
