Hello and thanks in advance. I just started working with PC-DMIS 2019 R1 and tried to use the Excel Form Report. Watching the short company video I was able to get it to output all my dimensions to a custom Excel sheet that I put in the Templates folder.
I have 3 sheets in this Excel file. The 1st sheet lists all the data. The 2nd sheet contains formulas that populate cells after reading data from the 1st sheet. The 3rd sheet contains a macro that further evaluates the data (pass or fail) from the 2nd sheet.
My problem is the PC-DMIS Excel Form Report only populates the 1st sheet with my data (or at least as far as I can see) because when I open the 2nd Sheet (Evaluation Sheet) or the 3rd Sheet (Non-Conformance Sheet) they both start with rows 1 and 2 then skip all the way down to rows 502, 503, etc...
Is there a way to correct this or open those sheets so that I can see if rows 3 thru 501 populated with anything? Any help is greatly appreciated.
