Array
  • Array
    I have 120 diameters I want to array but I don't want to list all 120 diameter.
    Anyway to array just the 1st and last one? ARRAY(CIR1 THRU CIR120)
    I don't want to have to so this ARRAY(CIR1, CIR2, CIR3 ect…..etct….CIR120)
    Have you tried using an incremental loop?
    Psuedo-code
    k=1
    while k<121
    append cir + k to array
    k++
      if I use incremental loop I can't go to a specific circle if I need to
      • JacobCheverie
        JacobCheverie commented
        Do you mean if you had more or less than 120 circles? Just do this and change j, you can even have a comment that asks for j.
        Psuedo-code
        k = 1
        j = 120
        while k < j + 1
        k++
      No way that I know of, and you'll have to do multiple arrays because the line length will be too long.
      I've requested in suggested features this functionality ARRAY(CIR1..CIR120), like pulling points from a scan.
      • programmer
        programmer commented
        I did multiple arrays ….but its not allowing me to ASSIGN/V10=MAX(V8,V9)
        see attachment
      • BKulpa
        BKulpa commented
        In your individual ARRAY's do V8=Max(array(
        Then try max(v8,V9)
      In a loop (V1 from 1 to 121), you can :
      ASSIGN/V2[V1]="CIR"+V1
      Which should give you the right array.
      Depends on what you want to do with, you can also create a feature set with CIR*
        if I use loop it would be more difficult to see a certain circles if there's an issue with it.
        • JEFMAN
          JEFMAN commented
          This loop only creates a array...
        BKulpa I tried " ARRAY's do V8=Max(array(
        Then try max(v8,V9)" still not working.
          In the first post, I understand that you want a single array with circles.
          In the #5, the attached file shows dimensions (.meas)
          I believe that ASSIGN/V2[V1]="ITEM73_"+V1+"_MIN_MAX.LOWER.MEAS" in a loop should create the single array, then you could ask for min and max of V2
          Maybe I didn't understand what you're looking for ?
