I'm probably posting this in the wrong area but maybe someone can help.. What is the surface finish standard (125 or better? 32 or better?) according to ASME Y14.5-1994 when it is not stated on the blueprint
surface finish question
Your customer will provide this information. If it's not on the print, then it is probably buried in a parts list, supplier quality requirements, or supplier spec. Y14.5 does not mandate a specific roughness. ASME B46.1 is the standard for surface texture. You can purchase one here:
https://www.asme.org/products/codes-...face-roughness
7107 Global Classic TP20
2019R1 SP1 CAD++
- 2 likes
Or you could dive into this tutorial from NIST
https://www.nist.gov/sites/default/f...ns/89-4088.pdf153010 Global Advantage w/ LSPX1H_T Analog Probe
2019R1 SP1 CAD++
- 1 like
Can some tell me what this means? My OG took the VSP and my NewGuy has a Electronics background. I think it means imperfections less than 3 microns in...
08-14-2009, 05:23 PM -
by bphillipsHelp settle the debate.
On the first page of the print there is a note:
13. (F) PERMISSIBLE TO FINISH PER SPEC XXX 2 11-1...-
05-11-2015, 03:05 PM -
by Guestanyone know what this print symbol means?
its on a metal stamping (small part) surface that has straightness and perp called out. also...-
03-30-2006, 07:47 AM -
by MadDuckSorry, this is not PC-DMIS related.
What’s the valley depth of 400-1600 surface finish?
We don’t have anything to check it with. The...-
01-24-2012, 03:42 PM -
by rockymcould anyone help me enable this features...
03-17-2008, 12:23 PM -
