I'm looking at a print (can't post) that has four cylinders (at an angle to centerline) that have a true position called out to where the cylinder intersects the OD (cylinder). I tried this several years ago and can't remember how ideas?
Intersect cross cylinder to od cylinder
Construct a constructed point with Pierce as the type. Select the cylinder defining the piercing axis first, then select the OD cylinder that will be pierced. If the point is created on the wrong side of the O.D. then construct a reverse line from the piercing cylinder. Then pierce the OD with that line.PC-DMIS 2016.0 SP8
Jeff
- 1 like
by hobbieI have been searching to find threads on how to extend line/vector created by a cylinder. Is there another way ask the question in the search engine?...
04-08-2009, 10:46 AM -
by JStewartGood morning!
I'm trying to create a cylinder between two existing cylinders and comng up empty. How is this done? Do I need to extract...-
11-19-2010, 09:48 AM -
by 12345I want to construct a line, parallel to the C/L of a cylinder
on the OD of the cylinder.
that is the I/O a plane and the cylinder
04-14-2009, 11:45 AM -
by cmmpro_mackI have two 0,0,1 circles and when I use them to construct a cylinder, the cylinder is 1,0,0. What is the problem.? Im using 4.3MR1.
Help...-
07-09-2009, 03:27 PM -
by TopherHi Guys,
I have a cylindrical part on a V-block. Datum A is Cylinder OD (250mm long), constructed in y- direction. I am then constructing...-
10-27-2017, 07:36 AM -
