Hello, I run a Sheffield Discovery II with 2018 R2. I use a probe rack with 5 different probes and my question is if I calibrate the probes I need in the morning and put them back in the rack do I need to recalibrate them every time I use them out of the rack? I am trying to find out how to change probes without always having to do a new calibration. I'm using a PH10T probe head. Go easy on me guys, I'm still learning. Thanks for any help.
Changing Probe Tips Without Calibrating
Unless the probe has been changed in the rack since the calibration, I don't see why you'd need to calibrate with each change. We calibrate in the morning, and go through many probe changes, often within a single program, and never calibrate once the initial daily calibration is complete. If it's clean, hasn't been crashed, etc, the CMM ought to know what it is.
Are you talking about an automatic probe changer? You don't need to recalibrate those every time you swap. If you did, you'd have to interrupt every program that had probe changes to recalibrate every time you swapped probes. I have a program that calibrates all the probes on my rack in DCC mode. I typically run it once a week, unless I bump something or I get odd results. Before I run it I inspect the probes for cleanliness, make sure everything is tight, and check my qual spheres the same way. All it takes is a little speck of something to throw off a calibration. Once a week is typically more than enough, my results are very consistent.
by orionHi all
Running PCDMIS 2013 MR1 ....
I would like to calibrate all my probes together first thing in the morning when I get...-
07-02-2014, 04:49 AM -
I have a Brown and sharp Image with a probe rack. normally I am able to calibrate the entire rack and the do a probe to probe verification to make sure...
06-29-2018, 02:11 PM -
by mdaviesI am new to the PC DMIS software and when we recalibrate tips we do all positions due to moving the sphere. Is this required or is there a way to recalibrate...
12-12-2007, 02:22 PM -
by CMM_DUDEGood Morning. We bought a used CMM and Hexagon set up this probe rack when they calibrated it. Recently I had to remove the rack to make room on the table....
12-18-2018, 11:45 AM -
by WolfManNormally when I would select to calibrate a probe that is not in the rack, it would put the current probe into the rack and then ask me to load a probe....
01-22-2014, 09:17 AM -
