To preface my question/comments.... I have looked though this forum for information on this topic and have come to the conclusion that the situation I am in may be worse then I had suspected.
After working in an area of inspection in our company for some time I inherited it by default. The other programmer quit and I was left holding the bag.
What is in the Bag:
Die inspection
Process: (which has been locked into place as an established process) Align to the top face/front edge(which is machined)/end(which is also machined) in a 3-2-1 structure. After which the impression is inspected using section or linear open scans that are dimensioned as a surface profile.
Results: Are inconclusive at best. This has not bred much confidence in the whole inspection process. Form and location can look ok for most of the profile and some of the points magnified and distorted or completely distorted. Note - the Deviation and OT are reported. which are not a good representation of how it is out of tolerance. Form only also can show some major distortion or results. By this I mean the graphical analysis view shows some of the profile points as way out of tolerance bands. Since taking over this area I have changed some of the Form Only profiles from Least squares to Vector Least squares. This has improved how the profile is represented in the Analysis view a the results in general.
The dies designs have been changing and the weakness of the to date inspection process is really showing. What is needed is the most accurate measurement of the impressions surface profiles and well as impression position on the Die.
What I have tried is to measure the impressions as is normally done as well as reporting the position of points within each scan section. After reading other posts I am uncertain that this is a viable, or even repeatable, way to go about this. See Code Below.
Bottom line: From what I have been reading, we have not been going about measuring and reporting the surfaces correctly. Simple sentence, but it carries the weight of upwards to 10,000 or more programs.
Goal: Appropriately/accurately measure and report the surface profile of each section of the impression.(perhaps an overall profile as well) Report the position of the impression to the die "matched edge". Ideally: be able to create a report of the position of the impression to the other half of the die set.(This is a future goal and haven't really looked into this yet)
I know this has been long, but I am in need of insight from some skilled programmers.
Thank you in advance!!
Regards,
David
What is in the Bag:
Die inspection
Regards,
David
