Sometimes Auto Circle (or etc) puts th path abov the desird circle instd of on th CAD
  • Sometimes Auto Circle (or etc) puts th path abov the desird circle instd of on th CAD
    Pic attached. Please see the dialog box settings, it seems like I have it set up normally and that it should place the path on the CAD surface with this configuration.
    This will happen randomly (on any program I make, ever since the system was installed brand new) and can be eventually fixed by clicking on other features and back to the feature I want.
    The following is the code I am currently working on, where I am inserting an auto-circle at the end, but this is just one example. The glitch happens at random on any CAD I am working on.
    ALIGNMENT/END
    MODE/MANUAL
    PREHIT/0.04
    RETRACT/0.04
    MOVESPEED/ 275
    MANRETRACT/0.01
    TEMPCOMP/METHOD = AUTOMATIC,MATERIAL = Stainless steel,CTE=17.3
    ,SET WARNING LIMIT = FALSE,MINIMUM = 10,MAXIMUM = 40
    ,PART SENSOR NUM=DEFAULT,X SCALE= 22.4543,Y SCALE= 22.303,Z SCALE= 22.4853,PART TEMP=22.0404
    LOADPROBE/MED-3-30-30
    COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO,
    PLACE PART ON CMM SURFACE WITH
    DATUM-B DOWN
    ALIGN 180°-APART HOLES WITH X-AXIS
    AS CLOSE AS POSSIBLE TO "BK" ROW
    PART-MARKNG SHOULD FACE
    OPERATOR ON -Y END OF TABLE
    PROBE THREE POINTS ON PLATE
    AROUND PART FOR DATUM-B
    TAKE CARE TO PROBE ONLY FLAT
    SURFACES, AVOID HOLES
    PLN1 =FEAT/PLANE,CARTESIAN,OUTLINE
    THEO/<0,-0.6667,0>,<0,0,1>
    ACTL/<17.36,29.5668,-33.3585>,<-0.0000607,-0.000083,1>
    MEAS/PLANE,3
    HIT/VECTOR,<-12,6,0>,<0,0,1>,<4.191,37.7334,-33.3587>
    HIT/VECTOR,<0,-14,0>,<0,0,1>,<18.2251,15.7246,-33.3596>
    HIT/VECTOR,<12,6,0>,<0,0,1>,<29.664,35.2425,-33.3573>
    ENDMEAS/
    ALIGNMENT/LEVEL,ZPLUS,PLN1
    ALIGNMENT/TRANS,ZAXIS,PLN1
    ALIGNMENT/END
    PROBE THREE POINTS IN CENTER BORE
    CIR1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<0,0,3.42>,<0,0,1>,2.25
    ACTL/<16.6384,29.7489,3.42>,<0,0,1>,2.2508
    TARG/<0,0,3.42>,<0,0,1>
    START ANG=0,END ANG=360
    ANGLE VEC=<1,0,0>
    DIRECTION=CCW
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=YES
    NUMHITS=3,DEPTH=0.25,PITCH=0
    SAMPLE METHOD=SAMPLE_HITS
    SAMPLE HITS=0,SPACER=0
    AVOIDANCE MOVE=NO,DISTANCE=0.3937
    SHOW HITS=NO
    PROBE THREE POINTS
    INSIDE 1.00 DIA THRU HOLE
    AT Y+ END OF THE TABLE
    CIR2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<0,7,3.5>,<0,0,1>,1
    ACTL/<16.65,36.7486,3.5>,<0,0,1>,1.0078
    TARG/<0,7,3.5>,<0,0,1>
    ANGLE VEC=<1,0,0>
    DIRECTION=CCW
    SHOW HITS=NO
    ALIGNMENT/ROTATE_CIRCLE,YPLUS,TO,CIR1,AND,CIR2,ABOUT,ZPLUS
    ALIGNMENT/TRANS,XAXIS,CIR1
    ALIGNMENT/TRANS,YAXIS,CIR1
    ALIGNMENT/END
    MODE/DCC
    MOVE/POINT,NORMAL,<0.0384,7.1349,4.1396>
    PLN2 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,OUTLINE,LEAST_SQR
    THEO/<0,0,3.508>,<0,0,1>
    ACTL/<0,0,3.5074>,<0.000008,-0.0000051,1>
    TARG/<0,0,3.508>,<0,0,1>
    ANGLE VEC=<-1,0,0>,SQUARE
    NUMHITS=2,NUMROWS=3
    SPACER=0
    SHOW HITS=NO
    MOVE/POINT,NORMAL,<-0.01,-6.9558,3.909>
    I believe your Auto Circle path is above your CAD because you have a depth of positive .375. For outer diameters, you depth should be negative. For inner diameters, your depth should be positive.
    • UseAsIs
      UseAsIs commented
      I know that changing it to negative will force it the opposite direction, but I don't seem to remember it doing it consistently on OD's as opposed to ID's. The Hexagon class definitely did not ever mention anything like that. I feel like it happens on ID's as well, but I only have this example at the moment.
      I will test out your suggestion and share my results, thanks.
      It's crazy how many little things PC-DMIS has that you have to "just know" that aren't in any Help files or manuals or anything. The whole classroom course at Hexagon went over Auto Features and never once mentioned anything like this. I even have the course manual at my desk and it doesn't say that. Ehhh... oh well.
    • UseAsIs
      UseAsIs commented
      I cancelled the circle, and clicked it again for another circle, and this time it used the same positive value but put it in the right location. PC-DMIS is just buggy and does this nasty stuff all the time, all day long. I have had endless problems with Path Lines in the graphic window. Half the time they won't even show up when I toggle them on, and I have to restart the software and reopen my program a few times before they will show up. Then when they do, I have to make sure they're even showing up in the right place
      Originally posted by UseAsIs View Post
      Turn the void detection OFF.
      7107 Global Classic TP20
      2019R1 SP1 CAD++
      • UseAsIs
        UseAsIs commented
        I'll try that. I never use it anyway since I prefer to manually create my move points
      In all versions of PC-DMIS I've used since the turn of the century I.D. autocircles move down the vector with a positive depth and O.D. autocircles move up the vector for a positive depth.
      That being said, I wouldn't put it past the Hexagon Imagineers to re-invent the wheel to make it hexagon shaped instead of circular or to rework a feature to make it different after 20 years.
      PC-DMIS 2016.0 SP8
      Jeff
