I want to measure a plane in a circular motion of a known diameter. I am using PC DMIS CAD++ 2011. Is this possible?!
Circular Plane
Auto feature plane allows creating circular planes. Just select "radial" in the auto plane, enter the radius, and select only 1 row. Select also circular moves.
You can also use vector points with a copy / paste with pattern. Be carefull to moves between hits in this case.
- Likes 1
Autoplane, Select "Radial" under "Pattern", make sure the "Void detect" button is not pressed, set your number of rows, number of hits, and "Spacer".
Note that in that old version the "Spacer" distance will be used both for distance from center to first ring, distance between hits, and distance between rings. In newer versions there's the more flexible "TTP plane circle" strategy where (among other things) those distances are separated.
CircularPlane.PNGAndersI
- Likes 1
Another way is to go INSERT - SCAN - CIRCLE then select TYPE plane enter the nominals as required this option allows full contact or single hits.
- Likes 1
by hobbiehow do I switch from straight line movement of probe to circular? when checking a plane in a groove I have to rise above and create a movepoint....can't...
08-17-2017, 08:24 AM -
by randy zPcdmis 2011 mr1
What is the best way to measure a circular plane. I have tryed using Auto Feature PLN and activating the circular move...-
05-10-2012, 02:11 PM -
by ADAM WALLACEIm having ttrouble with creating circular planes. When auto feat dialog boxes open with radial pattern set, circular move toggled and and measure now...
10-24-2012, 01:30 PM -
by CliffCan anyone tell me, how to create a plane without a CAD model using the Auto Plane feature with a good number of points? The surface is a flat circular...
07-27-2012, 11:31 PM -
by lambo(measure plane)
I took several hits on top surface of a ring gage with joy stick and then insert circular move between hits, when I execute the...-
05-28-2008, 11:02 AM -
