Inquiry about pc dmis programs
  • Inquiry about pc dmis programs
    hello
    i just wanted to ask you weather the programes created on a machine can on work on another cmm machine ? i guess the probe settins and angles are all what will need updating right ?
    It also Depends if it’s the same version like 2018 R2 to R1 and if u r analog scanning to touch trigger.
    But yes checking the probes and angles would need to be done once it has been moved to another machine.
      You need to have the same version as in CAD++ has features that may not be recognized in PRO.
        If you are using multiple angles in a single program, move points will also need to be adjusted if you have different heads/probes on the different CMMs
          Also, it may translate from one machine to another, if you're using a read point or manually locating to start the program. Otherwise, the stop locations/machine home may be different.
            of course, you 'll need to build similar probes. Good luck getting a 3x50mm stylus where a 2x80 was probing, lol.
