Is there a probe setter that can be bought. I have a TIGO SF and need to set me star probes. I have looked on the HEX MAF. site and have not been able to locate anything that will help me properly set my stylus to ensure they are square.
Stylus setter
I don't know about a setter, but isn't visual alignment against the datum sphere enough? Assuming you have the same tip size left and right, position the rightmost tip in front of the sphere, as close you can without touching, lock the CMM axis that would move the tip closer to the sphere, move up, right, down, so the leftmost tip is in the same position in front of the sphere. If not square, rotate the star half the visible diff and redo from start.
I've tried this and the problem is that when I have to adjust, I have to take off and loosen, adjust retighten and then put on probe, bring closer to sphere and try to ensure that they are aligned properly. This causes issues with productivity.... And no, both tips were not the same size, however that's not that big of an issue...
Thanks for the feedback
When I aligned the star probe, I had two long probes, same size, same length on opposite ends (so in only one axis) tightened to the knuckle. I put two standoffs on the plate in the same axis. I had the star bolt slightly loosened. I move the probe so the shafts of the stylus would bump against both standoffs to "square" them to the table. At that point, I then tightened the star up and double checked the squareness against the standoff locations. Knowing that the star was square, then I built the probe as I needed.
- Likes 4
I am trying to calibrate my #3 tip in position #5 on a 5 way. The tip is a 1 x 21 which is about 2 months old. I have deleted the saved probe file and...
11-20-2008, 12:32 PM -
by stevestewartI am using a 5 way star probe and I have tip 3 set in an upward direction at 70 degrees and tip 5 set in an upward direction at 63 degrees . Any recommendation...
04-12-2017, 11:35 AM -
by bphillipsI added a second MCR20 to the machine last week.
Changed my Master Tip to a 4x10mm A0B0 only(slot 1).
Ran the auto-cal routine so all eight...-
09-12-2015, 09:13 AM -
by MrCommentThe nuts and bolts of my Question related to the following Message box comment: (see attached jpeg also)
I recently got a Dual...-
07-03-2007, 03:22 PM -
by BoomerIs it posible to use multiple qual spheres....
1. calibrate a star probe on a qual sphere vector 0,1,0
2 calibrate a single...-
06-08-2007, 06:02 PM -
