I have seen this happening a lot in my Programs. It seems to be happening just with the Scanned lines, when done in mm. writing the programs, all fine and dandy, after running the program. It Projects my lines away from the part, giving me false readings. Will share my Code to show you the after results. Depth on all features are 1.5 mm on my auto feature settings. If you notice the X value goes wacky toe-backy. X being my primary plane. where my scanned circle holds the value. Depth is set the same.
Maybe look into this Don Ruggieri ?
CIR11 =FEAT/CONTACT/CIRCLE/ADAPTIVE_CIRCLE_SCAN,CARTESIAN,IN,LEAST_SQR THEO/<[COLOR=#EE82EE]40.5[/COLOR],0,0>,<1,0,0>,51 [COLOR=#FF0000] ACTL/<40.5,-0.005,-0.032>,<1,0,0>,51.016[/COLOR] TARG/<40.5,0,0>,<1,0,0> START ANG=270,END ANG=450 ANGLE VEC=<0,0,-1> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO LIN9 =FEAT/CONTACT/LINE/ADAPTIVE_LINEAR_SCAN,CARTESIAN,UNBOUNDED THEO/<[COLOR=#EE82EE]40.5[/COLOR],25.5,1.125>,<0,0,1>,<0,-1,0>,<-1,0,0>,44.95 [COLOR=#FF0000] ACTL/<78.101,25.753,2.795>,<0,-0.0003722,0.9999999>,<0.0068002,-0.9999768,-0.0003722>,<-0.9999769,-0.0068002,-0.0000025>,41.5[/COLOR] TARG/<40.5,25.5,1.125>,<0,0,1>,<0,-1,0>,<-1,0,0> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO LIN10 =FEAT/CONTACT/LINE/ADAPTIVE_LINEAR_SCAN,CARTESIAN,UNBOUNDED THEO/<[COLOR=#EE82EE]40.5[/COLOR],-25.5,1.125>,<0,0,1>,<0,1,0>,<1,0,0>,44.95 [COLOR=#FF0000] ACTL/<78.448,-25.264,2.798>,<0,-0.0002361,1>,<-0.0068005,0.9999768,0.0002361>,<0.9999769,0.0068005,0.0000016>,41.502[/COLOR] TARG/<40.5,-25.5,1.125>,<0,0,1>,<0,1,0>,<1,0,0> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO
