***EDIT: In classic PC-DMIS fashion, it just started working. I just kept running it and opening the report, and the input is now showing up on the report. I dunno ¯\_(ツ)_/¯
For reasons that are more tedious than they are relevant, I am trying to have the operator check something early in the program and type text into an Input Comment. Later, at the end of the program, I have assigned that input from the operator into a new Input Comment which will display on the report where I want it to be.
The text is showing up in the value when I build the Expression and the Assignment is correctly configured. Unfortunately, the text is not showing up in the second Comment's input field when I execute the first Input Comment as a block-exe. When I scroll to the end of the program, select the Destination comment, the Status window shows my default text, but not the text assigned from the original Operator Input.
I have built and re-built the assignments and expression and it just will not show up on the report or the status window. The Destination comment is configured to display on Report, but it will only display the default text and the Input field is blank even though the expression-builder shows the text from the first Source comment when I F9 it and investigate.
Is this a bug? Can anyone duplicate this? Is there a specific reason one would not be allowed to do this?
Thanks for any info you may have for me!
