When creating FCF's occasionally ill have an issue where the Datum Shift and Summary label will be missing. Also if i'm trying to report out 2 axis sometimes 1 axis will be missing from the report. The only fix i can come up with is opening the program in 2018 R1 edit and close each FCF and everything RE-appears. I can then open it back up in 2019 R1 with everything intact. This doesnt happen with all FCF's
See attached link for example
https://ibb.co/DCBSL8D
