I have a loop within a loop.
The inner (nested) loop is a 3x loop and that lies within a 5x loop
The features for the 5x loop are reporting correctly but when I dimension the inner loop's loops [3,5] it will reports the same data for each itteration.
Example:
in the edit window i have "Feautre[1,2]" but on the report it shows as "Feature[1,1]"
Example:
DIM STEP7_PLN1_4= LOCATION OF PLANE PHPLNSTP7[1,4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS Z 0.000 -0.001 ----#---- END OF DIMENSION STEP7_PLN1_4 DIM STEP7_PINHOLE1_4= LOCATION OF CIRCLE PHCIRSTP7[1,4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 0.000 0.001 ----#---- Y 0.000 -0.001 ----#---- Z 0.000 0.000 ----#---- D 5.000 3.485 <-------- END OF DIMENSION STEP7_PINHOLE1_4 COMMENT/REPT, $$$$$$ DIM STEP7_PLN2_4= LOCATION OF PLANE PHPLNSTP7[2,4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS Z 0.000 -0.004 ----#---- END OF DIMENSION STEP7_PLN2_4 DIM STEP7_PINHOLE2_4= LOCATION OF PLANE PHPLNSTP7[2,4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 0.000 -0.007 ----#---- Y 0.000 0.241 --------> Z 0.000 -0.004 ----#---- D 0.000 0.000 ----#---- END OF DIMENSION STEP7_PINHOLE2_4 COMMENT/REPT, $$$$$$ DIM STEP7_PLN3_4= LOCATION OF PLANE PHPLNSTP7[3,4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS Z 0.000 -0.007 ----#---- END OF DIMENSION STEP7_PLN3_4 DIM STEP7_PINHOLE3_4= LOCATION OF CIRCLE PHCIRSTP7[3,4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 0.000 0.000 ----#---- Y 0.000 0.002 ----#---- Z 0.000 -0.005 ----#---- D 5.000 3.485 <-------- END OF DIMENSION STEP7_PINHOLE3_4 DIM STEP7_SMR_14OF5= LOCATION OF SPHERE S7SMR1[4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 46.633 46.144 <-------- Y 167.370 167.834 --------> Z -196.381 -196.243 --------> D 12.700 12.704 ----#---- END OF DIMENSION STEP7_SMR_14OF5 DIM STEP7_SMR_24OF5= LOCATION OF SPHERE S7SMR2[4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 46.578 45.492 <-------- Y 151.177 151.220 ------#-- Z -136.533 -135.468 --------> D 12.700 12.705 ----#---- END OF DIMENSION STEP7_SMR_24OF5 DIM STEP7_SMR_3_4OF5= LOCATION OF SPHERE S7SMR3[4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 46.539 46.095 <-------- Y 160.688 160.614 -#------- Z -95.111 -93.652 --------> D 12.700 12.706 ----#---- END OF DIMENSION STEP7_SMR_3_4OF5 DIM STEP7_SMR_4_4OF5= LOCATION OF SPHERE S7SMR4[4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 35.915 35.956 ------#-- Y -99.332 -101.077 <-------- Z 90.998 91.416 --------> D 12.700 12.706 ----#---- END OF DIMENSION STEP7_SMR_4_4OF5 DIM STEP7_SMR_5_4OF5= LOCATION OF SPHERE S7SMR5[4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 59.365 59.399 -----#--- Y -41.133 -40.854 --------> Z 145.992 146.484 --------> D 12.708 12.705 ----#---- END OF DIMENSION STEP7_SMR_5_4OF5 DIM STEP7_SMR_6_4OF5= LOCATION OF SPHERE S7SMR6[4] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 59.921 59.960 ------#-- Y 27.846 28.123 --------> Z 161.288 161.775 --------> D 12.720 12.704 ---#----- END OF DIMENSION STEP7_SMR_6_4OF5 COMMENT/REPT, $$$$$$ COMMENT/REPT, $$$$$$ DIM STEP7_PLN1_5= LOCATION OF PLANE PHPLNSTP7[1,5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS Z 0.000 -0.001 ----#---- END OF DIMENSION STEP7_PLN1_5 DIM STEP7_PINHOLE1_5= LOCATION OF CIRCLE PHCIRSTP7[1,5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 0.000 0.001 ----#---- Y 0.000 -0.001 ----#---- Z 0.000 0.000 ----#---- D 5.000 3.485 <-------- END OF DIMENSION STEP7_PINHOLE1_5 COMMENT/REPT, $$$$$$ DIM STEP7_PLN2_5= LOCATION OF PLANE PHPLNSTP7[2,5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS Z 0.000 -0.004 ----#---- END OF DIMENSION STEP7_PLN2_5 DIM STEP7_PINHOLE2_5= LOCATION OF CIRCLE PHCIRSTP7[2,5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 0.000 -0.006 ----#---- Y 0.000 0.002 ----#---- Z 0.000 -0.002 ----#---- D 5.000 3.485 <-------- END OF DIMENSION STEP7_PINHOLE2_5 COMMENT/REPT, $$$$$$ DIM STEP7_PLN3_5= LOCATION OF PLANE PHPLNSTP7[3,5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS Z 0.000 -0.007 ----#---- END OF DIMENSION STEP7_PLN3_5 DIM STEP7_PINHOLE3_5= LOCATION OF CIRCLE PHCIRSTP7[3,5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 0.000 0.000 ----#---- Y 0.000 0.002 ----#---- Z 0.000 -0.005 ----#---- D 5.000 3.485 <-------- END OF DIMENSION STEP7_PINHOLE3_5 DIM STEP7_SMR_1_5OF5= LOCATION OF SPHERE S7SMR1[5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 46.633 46.145 <-------- Y 167.370 167.834 --------> Z -196.381 -196.245 --------> D 12.700 12.704 ----#---- END OF DIMENSION STEP7_SMR_1_5OF5 DIM STEP7_SMR_2_5OF5= LOCATION OF SPHERE S7SMR2[5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 46.578 45.493 <-------- Y 151.177 151.220 ------#-- Z -136.533 -135.469 --------> D 12.700 12.704 ----#---- END OF DIMENSION STEP7_SMR_2_5OF5 DIM STEP7_SMR_3_5OF5= LOCATION OF SPHERE S7SMR3[5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 46.539 46.095 <-------- Y 160.688 160.614 -#------- Z -95.111 -93.654 --------> D 12.700 12.705 ----#---- END OF DIMENSION STEP7_SMR_3_5OF5 DIM STEP7_SMR_4_5OF5= LOCATION OF SPHERE S7SMR4[5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 35.915 35.957 ------#-- Y -99.332 -101.077 <-------- Z 90.998 91.415 --------> D 12.700 12.706 ----#---- END OF DIMENSION STEP7_SMR_4_5OF5 DIM STEP7_SMR_5_5OF5= LOCATION OF SPHERE S7SMR5[5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 59.365 59.400 ------#-- Y -41.133 -40.854 --------> Z 145.992 146.483 --------> D 12.708 12.705 ----#---- END OF DIMENSION STEP7_SMR_5_5OF5 DIM STEP7_SMR_6_5OF5= LOCATION OF SPHERE S7SMR6[5] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS X 59.921 59.961 ------#-- Y 27.846 28.124 --------> Z 161.288 161.774 --------> D 12.720 12.704 ---#----- END OF DIMENSION STEP7_SMR_6_5OF5 COMMENT/REPT, $$$$$$
