I have a problem child .3mm probe tip that I needed to totally rebuild as it was consistently returning dubious results. Having deleted and rebuilt it I now must calibrate it. Here is my problem. I have a .75mm calibration sphere but I can;t edit the start and end angles. It is defaulted to 0 and 90 and all the selection boxes are grayed out so I can't change that to say 30 and 90. Right now it shanks out at the 0 degree start angle. Help?
Probe tip calibration question
A little more about this :
ASSIGN/V1=QUALTOOLDATA("xyz","the name of your sphere")
ASSIGN/V2=QUALTOOLDATA("diam","the name of your sphere")
Then measure an autosphere with the right angles at V.XYZ and V2 as diameter.
CALIBRATE ACTIVE TIP WITH FEAT_ID=SPH1, QUALTOOL_ID=the name of your sphere, MOVED=NO
AXIS THEO MEAS DEV STD DEV
X V1.X 8.0080 8.0080
Y V1.Y 1.0000 1.0000
Z V1.Z 0.9500 0.9500
DIAM V2 1.0000 1.0000 0.0000
Hope this helps
ftp://wilcoxassoc.com/docs/How%20To%...ibrateTips.zip
by JhartI know this is probably a easy fix but I am a rookie at programing so please excuse my ignorance. I want to add a tip angle (T1A90B0) to an existing probe...
08-21-2007, 06:48 PM -
by JP1234Morning guys ,
Its gotten to the point now where i am scared to calibrate certain probe angles. For the most part it is okay but certain...-
03-24-2021, 05:34 AM -
I'm trying to calibrate a 0.3 probe tip on the Global CMM. One issue is that I don't have a drop down selection for a 0.3 probe, the smallest available...
05-02-2022, 03:19 PM -
Hey all
We ve gotten a problem with our autocalibration program.
The first tip (master tip) calibrates normally. It starts in A0B0 and then...-
10-24-2019, 07:16 AM -
by giantslayerThe way our auto calibration program is set up now, all of the tips begin at the 90 0 and end with the 0 0 position. I want to change the order to where...
07-28-2014, 04:38 PM -
