I have a part with two surfaces called out for profile of .002"
When I scan the surfaces, one comes in fine (.0006") and the other comes in at around .058"
I thought the code was fine but I have posted it here and maybe somebody can help me if there is an issue.
Thank you.
Thank you.
$$ NO, ==================================================== ----------------- Manual Alignment ----------------- ==================================================== L1 =LABEL/ C4 =COMMENT/YESNO,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, DOES THE PART NEED A MANUAL ALIGNMENT? IF_GOTO/C4.INPUT == "NO",GOTO = L2 COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, TOUCH FOUR POINTS ON THE TOP PLANE PLN1 =FEAT/PLANE,CARTESIAN,TRIANGLE THEO/<0.0072,-0.0566,0.184>,<0,0,1> ACTL/<5.4605,-18.9502,-18.8761>,<-0.0006083,-0.0003869,0.9999997> MEAS/PLANE,4 HIT/BASIC,NORMAL,<0.229,-0.2663,0.184>,<0,0,1>,<5.4514,-18.6206,-18.876>,USE THEO=YES HIT/BASIC,NORMAL,<-0.1384,-0.3214,0.184>,<0,0,1>,<5.8579,-19.0266,-18.8759>,USE THEO=YES HIT/BASIC,NORMAL,<-0.3263,0.127,0.184>,<0,0,1>,<5.3553,-19.2585,-18.8763>,USE THEO=YES HIT/BASIC,NORMAL,<0.2647,0.2345,0.184>,<0,0,1>,<5.1775,-18.895,-18.8762>,USE THEO=YES ENDMEAS/ A1 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/END COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, TOUCH FOUR POINTS ON THE O.D. CIR1 =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-0.0275>,<0,0,1>,0.776,0 ACTL/<5.5016,-18.9841,-0.1095>,<0,0,1>,0.4005,0 MEAS/CIRCLE,4,ZPLUS HIT/BASIC,NORMAL,<-0.0056,0.388,-0.0278>,<-0.0143077,0.9998976,0>,<5.4925,-19.1842,-0.1099>,USE THEO=YES MOVE/CIRCULAR HIT/BASIC,NORMAL,<-0.388,-0.0048,-0.0278>,<-0.9999236,-0.0123604,0>,<5.6658,-19.0987,-0.1103>,USE THEO=YES MOVE/CIRCULAR HIT/BASIC,NORMAL,<0.0144,-0.3877,-0.0278>,<0.0370812,-0.9993123,0>,<5.538,-18.7871,-0.1099>,USE THEO=YES MOVE/CIRCULAR HIT/BASIC,NORMAL,<0.3879,0.0072,-0.0266>,<0.9998281,0.0185406,0>,<5.3343,-18.8739,-0.1078>,USE THEO=YES ENDMEAS/ A2 =ALIGNMENT/START,RECALL:A1,LIST=YES ALIGNMENT/TRANS,XAXIS,CIR1 ALIGNMENT/TRANS,YAXIS,CIR1 ALIGNMENT/END $$ NO, ==================================================== ----------------------- DCC ------------------------ ==================================================== L2 =LABEL/ COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, ENSURE PROBE IS LOCATED AT A SAFE DISTANCE ABOVE THE PART ENTERING DCC MODE MODE/DCC PLN2 =FEAT/PLANE,CARTESIAN,TRIANGLE THEO/<0.0012,-0.0003,0>,<0,0,1> ACTL/<0.0011,-0.0001,0.0001>,<-0.0003079,-0.0001973,0.9999999> MEAS/PLANE,4 HIT/BASIC,NORMAL,<0.0057,-0.3479,0>,<0,0,1>,<0.0055,-0.3477,0>,USE THEO=YES HIT/BASIC,NORMAL,<-0.3552,0.0093,0>,<0,0,1>,<-0.3552,0.0095,0>,USE THEO=YES HIT/BASIC,NORMAL,<0.0081,0.3426,0>,<0,0,1>,<0.008,0.3428,0.0001>,USE THEO=YES HIT/BASIC,NORMAL,<0.3462,-0.0051,0>,<0,0,1>,<0.346,-0.0048,0.0002>,USE THEO=YES ENDMEAS/ MOVE/POINT,NORMAL,<0.5,0,0.11> A3 =ALIGNMENT/START,RECALL:A2,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN2 ALIGNMENT/TRANS,ZAXIS,PLN2 ALIGNMENT/END DATUM_A =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-0.027>,<0,0,1>,0.776,1 ACTL/<-0.0001,0,-0.027>,<0,0,1>,0.7762,1 TARG/<0,0,-0.027>,<0,0,1> START ANG=0,END ANG=360 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=8,DEPTH=0,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0.3937 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=NO MOVE/POINT,NORMAL,<0.35,-.35,0.11> MOVE/POINT,NORMAL,<0,0,0.11> A4 =ALIGNMENT/START,RECALL:A3,LIST=YES ALIGNMENT/TRANS,XAXIS,DATUM_A ALIGNMENT/TRANS,YAXIS,DATUM_A ALIGNMENT/END OPTIONPROBE/MAXFORCE=0.36,LOWFORCE=0.06,UPPERFORCE=0.18,TRIGGERFORCE=0.06, PROBEACCURACY=0.1,POSACCURACY=0.1,#RETURNDATA=7, RETURNSPEED=1,SCANPNTDENSITY=16, SCANACCELERATION=10,SCANOFFSETFORCE=0.12, PROBINGMODE=DFL,MANFINEPROBING=NO SCANLOWER =FEAT/SCAN,LINEAROPEN,NUMBER OF HITS=17,SHOW HITS=NO,SHOWALLPARAMS=NO MEAS/SCAN BASICSCAN/LINE,NUMBER OF HITS=17,SHOW HITS=NO,SHOWALLPARAMS=NO ENDSCAN ENDMEAS/ SCANUPPER =FEAT/SCAN,LINEAROPEN,NUMBER OF HITS=14,SHOW HITS=NO,SHOWALLPARAMS=NO MEAS/SCAN BASICSCAN/LINE,NUMBER OF HITS=14,SHOW HITS=NO,SHOWALLPARAMS=NO ENDSCAN ENDMEAS/ MOVE/POINT,NORMAL,<0,0,0.11> MOVE/POINT,NORMAL,<0.5,0,0.11> DATUM_B =FEAT/PLANE,CARTESIAN,TRIANGLE THEO/<0.0751,-0.0904,-0.3475>,<0,0,1> ACTL/<0.0748,-0.0902,-0.3471>,<0,0,1> MEAS/PLANE,5 HIT/BASIC,NORMAL,<1.4691,-0.3231,-0.3448>,<-0.0024613,-0.0026191,0.9999935>,<1.4688,-0.323,-0.3477>,USE THEO=YES HIT/BASIC,NORMAL,<1.469,0.7605,-0.3418>,<-0.0024613,-0.0026191,0.9999935>,<1.4688,0.7606,-0.3477>,USE THEO=YES HIT/BASIC,NORMAL,<-1.0231,0.7456,-0.3481>,<-0.0024613,-0.0026191,0.9999935>,<-1.0232,0.7457,-0.3467>,USE THEO=YES HIT/BASIC,NORMAL,<-1.0087,-0.3034,-0.3507>,<-0.0024613,-0.0026191,0.9999935>,<-1.0089,-0.3032,-0.3466>,USE THEO=YES HIT/BASIC,NORMAL,<-0.531,-1.3314,-0.3523>,<-0.0024613,-0.0026191,0.9999935>,<-0.5313,-1.3313,-0.3466>,USE THEO=YES ENDMEAS/ MOVE/POINT,NORMAL,<-0.5389,-1.3405,3.5339> MOVE/POINT,NORMAL,<1.3255,2.9916,7.9557> $$ NO, ==================================================== ---------------- Datum Definitions ----------------- ==================================================== DATDEF/FEATURE=DATUM_A,A DATDEF/FEATURE=DATUM_B,B $$ NO, ==================================================== ------------------- Measurements ------------------- ==================================================== FCFPROF1 =LINE PROFILE : SCANLOWER FEATCTRLFRAME/SHOWPARAMS=YES,SHOWEXPANDED=YES CADGRAPH=BOTH,REPORTGRAPH=OFF,TEXT=OFF,MULT=10.00,ARROWDENSITY=100,OUTPUT=BOTH,UNITS=IN CUSTOMIZED DRF=NO STANDARDTYPE=ASME_Y14_5 PRIMARY DIMENSION/PROFILE OF LINE,0.002,<UZ>,<UTol>,A,<MC>,B,<dat> NOTE/FCFPROF1 FEATURES/SCANLOWER,, FCFPROF2 =LINE PROFILE : SCANUPPER FEATCTRLFRAME/SHOWPARAMS=YES,SHOWEXPANDED=YES CADGRAPH=OFF,REPORTGRAPH=OFF,TEXT=OFF,MULT=10.00,ARROWDENSITY=100,OUTPUT=BOTH,UNITS=IN CUSTOMIZED DRF=NO STANDARDTYPE=ASME_Y14_5 PRIMARY DIMENSION/PROFILE OF LINE,0.002,<UZ>,<UTol>,A,<MC>,B,<dat> NOTE/FCFPROF2 FEATURES/SCANUPPER,,
