My callout nominals are changing randomly Running 2016 Release and this has been happening when I even ran the version before this version 2012 MR1. My solution was to make my nominal (example 1.5000+0) adding a +0 to the nominal and it has been working but yesterday I noticed that it looked like the actual in the callouts has not updated per run. Has any got a fix or a suggestion. Thanks
Nominals are changing
Weird, the "fix" was implemented in PC-DMIS version 2015 I think.
Open up the settings editor and connect.
Search for "UseTheosForCADToPartLevelAlignment" and check the value. If it is "FALSE" set it to "TRUE" and save.
Start PC-DMIS and run your program.
Check the "Ignore CAD-Part" under the F5 settings, make sure it is not checked.PC-DMIS CAD++ 2o23.1
After I key new nominals while editing features and then run the program of feature, they change. Why? How do I make PC-DMIS keep them as I key them in?...
10-27-2011, 10:37 AM -
by MIKEYMy nominals are changing, plz help. I know I fixed that problem a long time ago but now all my setting are gone I have to fix everything all over again....
07-25-2008, 10:40 AM -
Started running 4.3mr1 this week and This is what I'm seeing happen. When you open up a program and save it to ver 4.3mr1 it is changing some of my nominals...
01-06-2009, 01:45 PM -
by eestleWe are running PC-DMIS 3.7mr2. We have this chronic problem with nominals "automagically" changing without warning. We have the "find...
01-05-2007, 12:44 PM -
Have a issue... I was working on one of my program and I was promted, "Do You Want To Updated Nominal" and I clicked on Do Not Ask Again......
07-12-2010, 11:39 AM -
