We are in the process of switching over from 2016 to 2018 and having issues with our first alignment. For some reason when the probe comes down to take hits on the first plane its missing the part. The same program works fine in 2016 and I cannot figure out what is going on. Thank you in advance for any help/
Pc dmis 2018
Open your external alignment program (i.e the program which creates the external alignment) and re-execute in PC-Dmis V2018 to update the .ALN file (check file date and time). Simply copying the V2016 .ALN files across doesn't always carry across correctly.
We have seen similar problems when updating from V2012 to V2016, yet didn't encounter problems when going from V2016 to V2018.
Hope this is of some use !
- 1 like
I switched from 2018 R2 to 2020 R1 and on a program I have I' m getting some really bad info. Same program works fine on 2018 R2 But when I run it on...
07-23-2020, 01:53 PM -
by BlueRayI run a Romer 7535 arm, and have just upgraded to pc dmis 2018 R2 last week. Typically we use a free form alignment (best fit) for the contoured parts...
Channel: PC-DMIS Portable
08-14-2018, 08:43 AM -
by Gabe prgI have a question, is there a way that PC dmis 2020 knows what probe it has after i ran PC-dmis 2018? We have a probe rack and when i switch from 2018...
02-04-2021, 12:25 PM -
by browningdmisI just updated my PCD software to 2018 SP 9 I think from like SP 2. Anyways I am running my first program and the alignment seams to be not working correctly...
02-01-2021, 03:10 PM -
