Resolved:
PCDMIS CAD++ 2013 MR1
Hi All,
I am at a new job and getting to work with some new things!
I have created a linear closed scan from my IGES model and it looks like it generates the scan path where I want it - wrapping around the OD of a rectangular boss with rounded corners.
However, when I perform Collision Detection, I can see the probe is trying to scan around the inside of the part - like the whole dimension is smaller than the features I clicked on to make the scan.
If I try to run on the actual part, I get the same results/ the CMM errors out with a 'maximum probe deflection' emergency error.
I've tried recreating the scans. I've tried shelling the program and doing only the alignment, then the scan. Same results.
This scan did work in a previous program that was written before any of us who currently work here. We are trying to re-write it because we'd like it to be in inches when we loop the program.
Thanks in advance!
EDIT: Could post #5 here be causing this type of problem? Tesselation from the model?
https://www.pcdmisforum.com/forum/pc...profile-oddity
Hi All,
Thanks in advance!
