Hello,
After performing my manual align and going to DCC mode, it goes to take the first hit and it is nowhere near where I programmed it to be. I do not understand the disconnect.
Before missing that 1st point it also ignores my move to clear plane and move point. Just goes to PNT_A1 and misses bad.
Please advise.
ALIGNMENT/END
MODE/MANUAL
MOVESPEED/ 100
TOUCHSPEED/ 5
MANRETRACT/0.1
FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;MEAS,NOM,TOL,DEV,OUTTOL, ,
TEMPCOMP/METHOD = AUTOMATIC,MATERIAL = Aluminium,CTE=23
,SET WARNING LIMIT = TRUE,MINIMUM = 18,MAXIMUM = 22
,PART SENSOR NUM=DEFAULT,X SCALE= 21.16971,Y SCALE= 20.89116,Z SCALE= 21.27795,PART TEMP=21.25733
LOADPROBE/1_5X20
TIP/T1A90B-90, SHANKIJK=1, 0, 0, ANGLE=-90
WORKPLANE/XPLUS
ROUGH_ALIGN=GROUP/SHOWALLPARAMS=YES
PNT1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<0,-7.07215,8.39588>,<1,0,0>
ACTL/<374.42221,293.87523,-623.39151>,<0.995991,-0.0391065,-0.0804521>
TARG/<0,-7.07215,8.39588>,<1,0,0>
SHOW FEATURE PARAMETERS=NO
SHOW CONTACT PARAMETERS=YES
AVOIDANCE MOVE=NO,DISTANCE=10
SHOW HITS=NO
PNT2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<0,7.38453,7.70848>,<1,0,0>
ACTL/<374.16016,308.79828,-623.38878>,<0.995503,-0.0431848,-0.0843144>
TARG/<0,7.38453,7.70848>,<1,0,0>
SHOW HITS=NO
PNT3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<0,0.03952,-5.70117>,<1,0,0>
ACTL/<374.25977,300.99566,-637.5842>,<0.9954177,-0.0352639,-0.088882>
TARG/<0,0.03952,-5.70117>,<1,0,0>
SHOW HITS=NO
PLN1 =FEAT/PLANE,CARTESIAN,OUTLINE,NO,LEAST_SQR
THEO/<0,0.1173,3.46773>,<1,0,0>
ACTL/<374.27756,301.18048,-628.18292>,<0.9998419,0.0175858,-0.0026467>
CONSTR/PLANE,BFRE,PNT1,PNT2,PNT3,,
OUTLIER_REMOVAL/OFF,3
FILTER/OFF,WAVELENGTH=0
CIR1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
THEO/<-5.6778,0,0>,<1,0,0>,38.075,0
ACTL/<-5.6778,300.81198,-631.80207>,<1,0,0>,38.08515,0
TARG/<-5.6778,0,0>,<1,0,0>
START ANG=-75,END ANG=73
ANGLE VEC=<0,0,-1>
DIRECTION=CW
NUMHITS=3,DEPTH=-4,PITCH=0
SAMPLE METHOD=SAMPLE_HITS
SAMPLE HITS=0,SPACER=0
SHOW HITS=NO
CIR2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
THEO/<-10,7.27461,-4.2>,<1,0,0>,3.168
ACTL/<-10,307.78289,-636.27803>,<1,0,0>,3.14937
TARG/<-10,7.27461,-4.2>,<1,0,0>
START ANG=0,END ANG=360
ANGLE VEC=<0,0,-1>
DIRECTION=CW
NUMHITS=3,DEPTH=1,PITCH=0
SHOW HITS=NO
ENDGROUP/ID=ROUGH_ALIGN
ALIGNMENT/LEVEL,XPLUS,PLN1
ALIGNMENT/TRANS,XAXIS,PLN1
ALIGNMENT/TRANS,YAXIS,CIR1
ALIGNMENT/TRANS,ZAXIS,CIR1
ALIGNMENT/ROTATE_CIRCLE,YPLUS,TO,CIR1,AND,CIR2,ABOUT,XPLUS
ALIGNMENT/ROTATE_OFFSET,30,ABOUT,XPLUS
ALIGNMENT/END
MODE/DCC
WORKPLANE/XPLUS
CLEARP/XPLUS,10,XPLUS,0,ON
MOVE/POINT,NORMAL,<10,-19.59873,-4.60102>
DATUM_ALIGN=GROUP/SHOWALLPARAMS=YES
MOVE/CLEARPLANE
PNT_A1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-11.85,-19.59873,-4.60103>,<1,0,0>
ACTL/<-11.85,-19.59873,-4.60103>,<1,0,0>
TARG/<-11.85,-19.59873,-4.60103>,<1,0,0>
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
PNT_A2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-11.85,-17.64739,9.862>,<1,0,0>
ACTL/<-393.36204,-345.88214,627.19325>,<0.9998419,-0.0176842,0.0018796>
TARG/<-11.85,-17.64739,9.862>,<1,0,0>
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
PNT_A3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-11.85,-0.48658,20.13464>,<1,0,0>
ACTL/<-393.08744,-329.1866,638.20252>,<0.9998419,-0.0176842,0.0018796>
TARG/<-11.85,-0.48658,20.13464>,<1,0,0>
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
PNT_A4 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-11.85,16.3216,11.64244>,<1,0,0>
ACTL/<-392.76938,-312.02791,630.44942>,<0.9998419,-0.0176842,0.0018796>
TARG/<-11.85,16.3216,11.64244>,<1,0,0>
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
PNT_A5 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-11.85,19.99159,1.03853>,<1,0,0>
ACTL/<-392.67677,-307.90118,620.01519>,<0.9998419,-0.0176842,0.0018796>
TARG/<-11.85,19.99159,1.03853>,<1,0,0>
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
PNT_A6 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-11.85,18.46246,-7.7987>,<1,0,0>
ACTL/<-392.68027,-309.04462,611.11983>,<0.9998419,-0.0176842,0.0018796>
TARG/<-11.85,18.46246,-7.7987>,<1,0,0>
SNAP=NO
SHOW HITS=NO
PLN_A =FEAT/PLANE,CARTESIAN,OUTLINE,NO,LEAST_SQR
THEO/<-11.85,2.84049,5.04631>,<1,0,0>
ACTL/<-329.27424,-270.71629,519.96471>,<0.8261983,0.1110769,0.552320 7>
CONSTR/PLANE,BFRE,PNT_A1,PNT_A6,PNT_A5,PNT_A4,PNT_A3,PNT_ A2,,
MOVE/CLEARPLANE
CYL_B =FEAT/CONTACT/CYLINDER/DEFAULT,CARTESIAN,OUT,LEAST_SQR
THEO/<-11.6,0,0>,<1,0,0>,38.075,4.9222
ACTL/<-392.77563,-327.83005,618.10861>,<0.9998419,-0.0176842,0.0018796>,38.075,4.9222
TARG/<-11.6,0,0>,<1,0,0>
START ANG=67,END ANG=292
ANGLE VEC=<0,0,-1>
DIRECTION=CCW
NUMHITS=5,NUMLEVELS=2,DEPTH=1.5,END OFFSET=1.5,PITCH=0
SHOW HITS=NO
MOVE/CLEARPLANE
CIR_C =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
ACTL/<-391.03684,-320.40924,614.232>,<0.9998419,-0.0176842,0.0018796>,3.168
ANGLE VEC=<0,0,-1>
DIRECTION=CCW
NUMHITS=5,DEPTH=1,PITCH=0
AVOIDANCE MOVE=AFTER,DISTANCE=5
SHOW HITS=NO
ENDGROUP/ID=DATUM_ALIGN
DATUM_ABC =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
ALIGNMENT/LEVEL,XPLUS,PLN_A
ALIGNMENT/TRANS,XAXIS,PLN_A
ALIGNMENT/TRANS,YAXIS,CYL_B
ALIGNMENT/TRANS,ZAXIS,CYL_B
ALIGNMENT/ROTATE_CIRCLE,YPLUS,TO,CYL_B,AND,CIR_C,ABOUT,XPLUS
ALIGNMENT/END
DATDEF/FEATURE=PLN_A,A
DATDEF/FEATURE=CYL_B,B
DATDEF/FEATURE=CIR_C,C
Please advise.
ALIGNMENT/END
MODE/MANUAL
MOVESPEED/ 100
TOUCHSPEED/ 5
MANRETRACT/0.1
LOADPROBE/1_5X20
WORKPLANE/XPLUS
SHOW HITS=NO
SHOW HITS=NO
SHOW HITS=NO
ANGLE VEC=<0,0,-1>
DIRECTION=CW
SHOW HITS=NO
ANGLE VEC=<0,0,-1>
DIRECTION=CW
SHOW HITS=NO
ALIGNMENT/END
MODE/DCC
WORKPLANE/XPLUS
MOVE/CLEARPLANE
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
SNAP=NO
SHOW HITS=NO
MOVE/CLEARPLANE
ANGLE VEC=<0,0,-1>
DIRECTION=CCW
SHOW HITS=NO
MOVE/CLEARPLANE
ANGLE VEC=<0,0,-1>
DIRECTION=CCW
SHOW HITS=NO
ALIGNMENT/END
