I am trying to measure a rectangular plane 233 mm x 245 mm with points taken every 10 mm. I want to try an auto plane but cant find an option to set the boundaries for the plane. I do not have a CAD model for this part. It is a rush job and i don't have the time to program all 552 hits manually. Am i missing something that will allow me to set the auto plane up for this?
auto plane boundaries
by CarfinBear72Looking for a bit of help,
Trying to use the auto plane function for the first time. I'm taking a plane on a thin ring, so want to be able...-
08-08-2017, 10:19 AM -
Is there a way to rotate the start point of an auto plane by, say, 15°?
I am creating a plane on a circular part, in line with the axis,...-
02-28-2020, 11:41 AM -
How to change distance between points in auto plane without changing spacer value?
12-20-2019, 08:43 AM -
by jleondWhen I measure an auto plane with actual thickness selected (2mm) the actual meas is wrong, using a constructed plane from vector points (with 2mm actual...
08-29-2008, 11:09 PM -
by mrnonameHi,
I was wondering if anyone could tell me how PC-DMIS views a plane to plane dimension. What my boss would like to know is when you level and...-
10-24-2008, 12:14 PM -
