Seriously? Too much time spent on this workaround...
  • Seriously? Too much time spent on this workaround...
    v2017R2
    [code]OUTSIDE_SURFACE_SCANS=GROUP/SHOWALLPARAMS=NO
    ENDGROUP/ID=OUTSIDE_SURFACE_SCANS
    MOVE/CLEARPLANE
    BASICSCAN/LINE,NUMBER OF HITS=6,SHOW HITS=NO,SHOWALLPARAMS=NO
    ENDSCAN
    ENDMEAS/
    [\code]
    So I have a scan without it being a feature. This is doomed for failure. Unless...
    So I can't show you, can't copy the text because of the ENDGROUP, can't do a screenshot coz of some file size limit that I read about but don't care enough to look into. What I tried was creating an autofeature after the group, no help. Then a measured feature so I could get the ENDMEAS/ line. Still nothing. The only way I can add more scans is to change the group parameter to SHOWALLPARAMS=YES
    Now I can add more scans.
    Too much time spent figuring this one out, unless someone can tell me what I'm doing wrong.
    EDIT: For clarification, it won't let me create any scans outside the group unless I show everything in the group.
    Report it.
    PC-DMIS CAD++ 2o23.1
    • JEFMAN
      JEFMAN commented
      Maybe it will be fixed in the SP15 ?
    • BKulpa
      BKulpa commented
      I've seen this type of behavior too often.
      The Demon loves to disjoint alignments that are near the beginning and end of groups!
    I first encountered this bug with v2012: combining advanced scans with groups can occasionally result in this strange situation where the "outer wrapper" of the advanced scan - the first line(s) and last line(s) -becomes hidden underneath the code preceding and following the scan.
    it is an intermittent issue not easily duplicated, but it made me quit using Groups completely and forever.
    It can get even worse with entire Movepoints being hidden under overlapping edit window code.
    The solution is to brute-force delete everything in that region of the program. You should get a message like, 'Some hidden crap will be deleted as well, OK?" and you click Heck Yes and delete it. Then delete the groups and never use them again, especially in a program with scans.
      Sorry to bump an older thread but...
      I was having the same issue with v2015.0
      as RandomJerk said a quick right click / expand all alleviated the symptoms
      • John Kugler
        Scan Issues
        by John Kugler
        Can anyone tell me why my Scan ID is missing? This program has numerous scan in it already, but when I try to add a new one, I get the following. I...
        06-30-2012, 11:25 AM
      • Vertman
        Patch Scans..
        by Vertman
        Trying to reverse engineer a port , and i dont seem to be able to to do a contact patch scan, every time i pick the points (start, direction, end, end...
        02-11-2008, 05:52 AM
      • Liambo734
        Making Scans Parametric
        by Liambo734
        I was interested in finding out if anybody has managed to make scans parametric in a PCDMIS program. I have 10 sizes of part that all have different types...
        01-27-2016, 03:21 PM
      • bigtallanddopey
        hit type changing when scan executed
        by bigtallanddopey
        Hi Everyone
        I am having an issue with freeform scans where for some reason the scan hit type changes from vector to surface and I cannot...
        01-24-2018, 06:11 AM
      • Cal M
        Jumping Scans
        by Cal M
        I have program that I am proving out that has several scans, one right after the other. They are basic circle scans. When placing the cursor on or before...
        12-10-2008, 07:03 AM
