123
Probes
I believe there is a 25mmX1.5mm disc in the list. If that is the case, just add an additional 10mm extension to the build. PC-DMIS doesn't really care about the specific extensions and lengths as long as the end product provides the right total length. I have one currently that is a 55 mm length that is listed as a 1mmx30mm+10 mmext. + 5 mm ext. It works just fine. Also, is it a 3mm thread? If so it will need a convert to 2mm connector. At least after that addition you will find the variety of disc probes ion the category you are looking at. Hope this helps.Last edited by Jim Poehler; 05-06-2019, 02:38 PM. Reason: Changed size from 20mm to 25mm and added note about the conversion adapter.
Typically what I do, instead of reinventing the wheel with the custom probe builder, is go into the probe.dat file via notepad, find a similar probe file (like the 12.7BY31MMDISK) copy/paste it with your new probe name, then append the sizes to suit exactly what you ordered. Obviously, you'll need a bit of training on what value is what, but the help file within pcdmis is quite clear on this method.
Search "Editing the usrprobe.dat Data File" for the deets.
- Likes 1
Depending on your license it may not be there. There is no mention of the pc-dmis version being used. This is a snap of 2018R1.
This document might help (if you don't already have it): ftp://ftp.wilcoxassoc.com/docs/How%2...s/PROBFILE.DOC
by HemingI have 8mmby32mm long disk. It is not in the library. How can I customer define it?
11-11-2009, 11:23 AM -
by AmdgkHi,
Does anyone know of a good place that will supply a 5mm on 1,5mm shank disc probe or will supply custom made disc probes?
02-01-2013, 06:48 AM -
by WolfManI would like to know what is that little roller that is inside the disk is for? Is that the area that you should be measuring depth and thickness? If...
11-19-2013, 10:53 AM -
by lcrowstonI am having trouble with a probe build. I have a Ceramic 30mm x 1.5mm disk, this does not show up in the drop down, I had to install an m3 to m2 adapter...
07-11-2019, 01:04 PM -
by lcrowstonAs we fabricate numerous seal/o-ring grooves I have had to use Disk styli, they are very handy,
I was reading the Renishaw catalog and it was saying...-
11-28-2018, 05:53 PM -
