New Error
  • New Error
    Had this come up this morning and now the machine is dead in the water. Tried restarting the controller and computer and nothing helps.
    Anyone see this before and if so how did you correct it?
    Out of all the things I've lost.... I miss my mind the most!
    Is this a dual arm machine?
    Systems Integrator
      No is a bridge machine. Has no arms.
        Well we shut everything down and restarted and now everything works fine.
        No clue as to what caused the error.
          I'd guess you have an issues in the safety wiring since this error is basically telling me that you tried to switch from single to dual arm mode without following the proper procedure and triggered a safety fault.
          Could be a loose wire or a faulty board.
          Systems Integrator
            We did blow a 5 amp fuse last night. Have no clue as to why. The air filter was in bad shape so we replaced that. Had no errors or problems before the fuse went. Everything started up OK this morning after replacing the fuse. So far it's all working good.
