Hi all, I've got a closed scan that consists of mainly 8 arc-segments. I'm trying to extract 4 of the eight arc segments, which make a pattern in the scan. I can do it just fine with hit numbers, but the hit counts and vectors shift a bit between parts and runs, so i'm trying to make an assignment to extract an array, based upon an angle range of the vector points, to construct each circle (arc segment).
I don't know if this is possible or not. anyone willing to give it a shot?
Below Scan F34 is the example code. For the first array segment, I want the array to start as soon as I vector is < -0.89. Then once I vector is < -0.45, I want to stop the defined array segment.
--I understand that this will likely need to be a 2d array analysis (sampling K vector as second array), but if we get it running 1d, I'm sure I can work it into 2d.
something like this (maybe a while loop is required?)
Assign/V1=if(array(f34.hit[1..f34.numhits].I > -0.89 AND f34.hit[1..f34.numhits].K < -0.46, add index# to newly defined array)
i know this doesn't work properly, please consider it pseudocode to get the concept across.
Here's some sample code for the scan:
F34 =FEAT/SCAN,LINEARCLOSE,NUMBER OF HITS=600,SHOW HITS=YES,SHOWALLPARAMS=NO MEAS/SCAN BASICSCAN/LINE,NUMBER OF HITS=600,SHOW HITS=YES,SHOWALLPARAMS=NO --Omitted points to truncate post--- HIT/VECTOR,<-0.07751,0.39999,-0.18957>,<-0.9072013,-0.0043577,-0.4206743>,<-0.07751,0.39999,-0.18957>,T=0 HIT/VECTOR,<-0.07948,0.39999,-0.18539>,<-0.9046261,-0.0043534,-0.4261838>,<-0.07948,0.39999,-0.18539>,T=0 HIT/VECTOR,<-0.08149,0.39999,-0.18125>,<-0.8993904,-0.0043442,-0.4371247>,<-0.08149,0.39999,-0.18125>,T=0 HIT/VECTOR,<-0.08358,0.39998,-0.17713>,<-0.8919115,-0.0043305,-0.4521893>,<-0.08358,0.39998,-0.17713>,T=0 HIT/VECTOR,<-0.08574,0.39998,-0.17306>,<[B]-0.8831919[/B],-0.0043136[B],-0.4689921[/B]>,<-0.08574,0.39998,-0.17306>,T=0 [B]<---Start arc 1[/B] HIT/VECTOR,<-0.08798,0.39997,-0.16903>,<-0.8735597,-0.0042938,-0.4866981>,<-0.08798,0.39997,-0.16903>,T=0 HIT/VECTOR,<-0.09031,0.39997,-0.16505>,<-0.863718,-0.0042727,-0.5039573>,<-0.09031,0.39997,-0.16505>,T=0 HIT/VECTOR,<-0.09271,0.39996,-0.16111>,<-0.8537315,-0.0042503,-0.5206961>,<-0.09271,0.39996,-0.16111>,T=0 HIT/VECTOR,<-0.09519,0.39996,-0.15722>,<-0.8433996,-0.0042262,-0.5372701>,<-0.09519,0.39996,-0.15722>,T=0 HIT/VECTOR,<-0.09774,0.39995,-0.15338>,<-0.8326828,-0.0042004,-0.5537344>,<-0.09774,0.39995,-0.15338>,T=0 HIT/VECTOR,<-0.10037,0.39994,-0.14959>,<-0.8216439,-0.004173,-0.5699859>,<-0.10037,0.39994,-0.14959>,T=0 HIT/VECTOR,<-0.10307,0.39994,-0.14585>,<-0.8103061,-0.0041439,-0.5859922>,<-0.10307,0.39994,-0.14585>,T=0 HIT/VECTOR,<-0.10585,0.39993,-0.14217>,<-0.7986603,-0.0041134,-0.6017681>,<-0.10585,0.39993,-0.14217>,T=0 HIT/VECTOR,<-0.10869,0.39992,-0.13854>,<-0.7867015,-0.0040812,-0.61732>,<-0.10869,0.39992,-0.13854>,T=0 HIT/VECTOR,<-0.11161,0.39991,-0.13497>,<-0.7744382,-0.0040474,-0.6326366>,<-0.11161,0.39991,-0.13497>,T=0 HIT/VECTOR,<-0.1146,0.39991,-0.13146>,<-0.7617778,-0.0040118,-0.647826>,<-0.1146,0.39991,-0.13146>,T=0 HIT/VECTOR,<-0.11765,0.3999,-0.128>,<-0.7491295,-0.0039755,-0.6624117>,<-0.11765,0.3999,-0.128>,T=0 HIT/VECTOR,<-0.12078,0.39989,-0.12461>,<-0.735885,-0.0039368,-0.6770951>,<-0.12078,0.39989,-0.12461>,T=0 HIT/VECTOR,<-0.12397,0.39988,-0.12128>,<-0.7224608,-0.0038969,-0.6914009>,<-0.12397,0.39988,-0.12128>,T=0 HIT/VECTOR,<-0.12722,0.39987,-0.11801>,<-0.7087589,-0.0038555,-0.7054403>,<-0.12722,0.39987,-0.11801>,T=0 HIT/VECTOR,<-0.13054,0.39986,-0.1148>,<-0.6947833,-0.0038126,-0.719209>,<-0.13054,0.39986,-0.1148>,T=0 HIT/VECTOR,<-0.13392,0.39985,-0.11167>,<-0.6805414,-0.0037683,-0.7327>,<-0.13392,0.39985,-0.11167>,T=0 HIT/VECTOR,<-0.13736,0.39984,-0.10859>,<-0.6660364,-0.0037224,-0.74591>,<-0.13736,0.39984,-0.10859>,T=0 HIT/VECTOR,<-0.14085,0.39982,-0.10559>,<-0.6512762,-0.0036752,-0.7588318>,<-0.14085,0.39982,-0.10559>,T=0 HIT/VECTOR,<-0.14441,0.39981,-0.10266>,<-0.6362643,-0.0036265,-0.7714626>,<-0.14441,0.39981,-0.10266>,T=0 HIT/VECTOR,<-0.14803,0.3998,-0.09979>,<-0.6210085,-0.0035765,-0.7837956>,<-0.14803,0.3998,-0.09979>,T=0 HIT/VECTOR,<-0.1517,0.39979,-0.097>,<-0.6055129,-0.0035251,-0.7958277>,<-0.1517,0.39979,-0.097>,T=0 HIT/VECTOR,<-0.15542,0.39978,-0.09428>,<-0.589785,-0.0034723,-0.8075529>,<-0.15542,0.39978,-0.09428>,T=0 HIT/VECTOR,<-0.1592,0.39976,-0.09163>,<-0.5738294,-0.0034182,-0.8189677>,<-0.1592,0.39976,-0.09163>,T=0 HIT/VECTOR,<-0.16303,0.39975,-0.08906>,<-0.5576535,-0.0033627,-0.830067>,<-0.16303,0.39975,-0.08906>,T=0 HIT/VECTOR,<-0.1669,0.39974,-0.08656>,<-0.5412628,-0.003306,-0.840847>,<-0.1669,0.39974,-0.08656>,T=0 HIT/VECTOR,<-0.17083,0.39972,-0.08414>,<-0.5246636,-0.003248,-0.8513034>,<-0.17083,0.39972,-0.08414>,T=0 HIT/VECTOR,<-0.1748,0.39971,-0.0818>,<-0.5078631,-0.0031887,-0.8614319>,<-0.1748,0.39971,-0.0818>,T=0 HIT/VECTOR,<-0.17882,0.39969,-0.07954>,<-0.4908663,-0.0031282,-0.8712293>,<-0.17882,0.39969,-0.07954>,T=0 HIT/VECTOR,<-0.18288,0.39968,-0.07735>,<-0.4736814,-0.0030666,-0.8806909>,<-0.18288,0.39968,-0.07735>,T=0 HIT/VECTOR,<-0.18699,0.39967,-0.07525>,<[B]-0.4563129[/B],-0.0030037[B],-0.8898143[/B]>,<-0.18699,0.39967,-0.07525>,T=0 [B]<--End arc 1[/B] --Omitted points to truncate post---
