Roundness in ExactMeasure True Position
  • Roundness in ExactMeasure True Position
    Anybody else having an issue with roundness (form) NOT showing up in True Position in Exactmeasure? When we check the box for form in the dialog box, add the tolerance, it won't show up in the dimension in the report. If we change the tolerance in the Edit Window, it magically appears. Are we doing something wrong?
    PCDMIS 2019r1
    Thanks.
    Verified - I couldn't even get it to show up after editing the tolerance or nom for the 'RN' in the edit window...
    Running 2019 R1 SP2, added it to my "issues" thread.
    PC-DMIS CAD++ 2o22.1 SP2
      Just to be 'helpful' - it works without problem for me, 2019 R1 SP2. My steps were
      - import the HEXBLOCK cad model
      - measure a plane, datum A, ZPLUS, ZORIG
      - measure a line, datum B, XPLUS, YORIG
      - measure a Point, datum C, XORIG
      - align to A B C
      - measure a circle, dimension Xact TP ABC, check the RN box
      RN shows immediately in the status window, and it is there in the Report when I open it.
      So, something else must be involved, too - can you give your repeating steps?
        - align to A B C
        Our version:
        CAD++ Version 2019 R1 - Build #288
        Release Date: Feb 28 2019
        Our steps are similar. Fairly straight-forward.
          - align to A B C
          Tested in an already existing program on existing TP also created a new TP to no avail.
            Update: Updated PCDMIS to the latest version through Hexagon Universal Updater and issue has been resolved. Response from Tech Support also mentioned needing to update. Thanks to vpt.se for the assist.
              No worries, John Kugler , but I am running the latest version and I can't get it to work...
