Probing Threads From CAD.
  • Probing Threads From CAD.
    Good morning,
    I am working on a program that has threads in the holes. 10-32. What is the best way to go about this without using a locator? They want the diameter and TP.
    Darroll
    2018R2
    for the TP
    I use an auto circle set the pitch to .03125 (1\32)
    or if its a tight tolerance i use an auto cylinder setting the
    length .156 (5x pitch)
    depth .0625 (2x pitch)
    ending offset 0
    levels 3
    pitch .03125
    for the diameter i'd use calipers or gage pins for the minor (assuming female threads)
    • Darrollh
      Darrollh commented
      Thanks! That worked. Used autocylinder.
    you guys might think I'm crazy but I take a series of y- vector hits, moving 0.003" to 0.005" down in Z for each hit, for 1.5 the pitch length (in this case 0.047") then extract the min value as minor thread root. Then I origin Z to the point that has min value. Then, finally, I measure the autocircle as mckenzie states.
    • louisd
      louisd commented
      this makes sure you hit ON the minor, the whole way down, so long as the pitch is correct.
    if you have scanning ability you can try a cylinder line scan with a max inscribe filter it should give you the min dia. as well as location if size is not important you can do a cir or cylinder with pitch as stated above if you use the pitch method its best you go around 3 times and use a least square filter
    • Darrollh
      Darrollh commented
      Thank you! I am going to try that.
    • Darrollh
      Darrollh commented
      This is with using an Open Linear correct?
    • thomas pilc
      thomas pilc commented
      no its under cylinder
