When measuring a small arc segment, what are your preferred methods?
The reason why I ask, is because I usually use a high point density scan and construct a circle There is a program I am rewriting that used a method I'm not sure is proper. He took 4 points on the arc, constructed a circle, dimensioned profile of a line, took the measured value and added it to the nominal diameter, then dimensioned the radius using a generic feature. I understand the mind state, I'm just not sure if it is proper. I've heard about using "fixed radius" auto features but I haven't used it yet.
As always, your opinion is always appreciated.
