As the title says, the probe tip is hitting the part to be inspected, but the software isn't recording hits at all. The probe readout stays the same for all 3 axis's and the hit counter stays right at 0.
I've tried to restart the program and machine, calibrate the probe tip... but no luck. I think it could be the software itself that's simply not recognizing the hits for whatever reason. Has this happened to you? If so, what was the cause?
Edit: It works now, amazingly. I am still curious as to why PCDMIS stopped registering hits all of a sudden, though.
For anyone curious as to what I did: I wanted to see if the "Emergency Error" message would come up if I snagged the styli away from the probe head by hand. It did. When given the option to go back to the program or Shut Down, I decided to shut down PCDMIS and opened it up again. Whaddya know, the software now recognizes hits from the probe tip. It might have something to do with the communication between the machine and software. Any ideas are accepted so I know what to do next time.
