3 weeks between both sp...
https://www.wilcoxassoc.com/public/P...19_R1/SP2/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...19_R1/SP2/x64/
PCD-140680 - Fixed an issue where the clearance plane was not drawn in the
correct location when there was a part setup transform.
• PCD-151149 - Fixed an issue where the Pointcloud Surface Colormap
incorrectly appeared in the Feature List box in the Dimension dialog box.
• PCD-152016 - Made improvements to colormap so that it relates better to
the selected surfaces.
• PCD-153254 - Fixed an issue where 4-axis scanning was not available for the
Adaptive Plane Circle Scan strategy for the Plane Auto Feature.
• PCD-153551 - Fixed an issue where the Colormaps list box was inadvertently
set to None when the report was refreshed.
• PCD-154698 - Fixed an issue where Auto Plane, Auto Point, and Auto Trigger
functions did not work for Portable arms when you measured contact
features.
• PCD-157701 - Fixed an issue with animation where animating a hit could
have ended prematurely and given the impression of a bad retract.
• PCD-158089 - Corrected an issue where auto-insert moves ignored the
measured features.
• PCD-158353 - Fixed an issue where an auto wrist did not appear where it was
expected to appear (inside a Quick Align feature's groups).
• PCD-158362 - Fixed an issue where a cylinder could be solved as inner when
it was actually an outer cylinder.
• PCD-158727 - Fixed an issue where continuous scanning did not work when
you used an AT901 Tracker.
• PCD-158842 - Fixed an issue where a DCC command could be added to a
measurement routine that ran in Protected Mode.
• PCD-160232 - Fixed an accuracy issue that occurred when a rotary table was
switched on with Technology Server 1.5 on Leitz CMMs with a Leitz B5
controller.
• PCD-160255 - Fixed a crash that occurred when you deleted new features
with the auto wrist dialog open.
• PCD-160312 - Fixed an issue that occurred when you created linear open
scans with the auto-dimension setting enabled.
• PCD-160716 - Fixed a crash that occurred when you set the
DoNotUseAmyuniRTF registry entry in the Settings Editor application to 1 or
2.
• PCD-160827 - Fixed a crash that occurred when you loaded and executed a
measurement routine with DIMINFO commands inside a loop.
• PCD-161285 - Fixed an issue where measured features could be added to a
measurement routine that ran in Protected Mode (or Inspect) after you took
hits and pressed the Done button on the jog box.
• PCD-161286 - Fixed an issue where tip changes could be added to a
measurement routine that ran in Protected Mode (or Inspect) through
machine usage.
• PCD-161412 - Fixed a crash that occurred when you clicked the Measure
button in the Probe Utilities dialog box for the calibration of a CMS probe.
This issue occurred only in Online mode with FDC dual-arm controls and the
probe was marked for Arm2.
• PCD-162047 - Fixed an issue that affected bonus to appear when the input
features had different vectors.
• PCD-162368 and PCD-162690 - Added a Cookie Policy console at the bottom
of each help topic to give an easy way to enable or disable Help file tracking
analytics and an easy-to-find link to our Privacy Policy.
• PCD-162476 - Fixed a crash that occurred after you deleted a work plane and
updated all dimensions.
• PCD-162569 - Fixed an issue where Technology Server 1.5 ignored the prehit
and retract properties for scanning. Now, you need to set the retract
properties in DCC mode before scanning, similar to Manual mode.
• PCD-162652 - Fixed a crash that occurred when you selected multiple circles
in OCR mode.
• PCD-162732 - Fixed an issue where CAD model views were empty. This issue
only occurred when the measurement routine used inches.
• PCD-163100 and PCD-163222 - Fixed an issue that occurred when you
created an invalid QuickFeature.
• PCD-163223 - Fixed an issue where the setup default settings of the I++ Client
for Technology Server 1.5 on CMMs with a Leitz B5 controller were incorrect.
The change is described in the MIIM Help documentation.
• PCD-162715 - Fixed an issue that occurred when you selected ON from the
Report textual analysis list on the Reporting tab in the XactMeasure
GD&T dialog box. This selection always used to display zero bonus values in
the report.
• PCD-163766 - Fixed an issue where the Datum Definition dialog box didn't
display sets if it was opened from the main menu (Insert | Dimension |
Datum Definition).
• PCD-164530 - Made a change to set the EdgeClientNotifications
registry entry in the Settings Editor application to False by default.
• Changes were made to improve the user experience based on feedback
collected from re
features.
measured features.
controller.
2.
machine usage.
in OCR mode.
the report.
Datum Definition).
collected from re
