i am trying to report MAX(GX) MIN(GN). Can someone tell me if I am using the function right? See attached. I am measuring the circle under LSQ. Report it using GX, GN and Diameter of location of circle and getting different results. Capture.PNG
reporting MAX(GX) MIN(GN)
"You gave GX for both upper and lower." i gave it the +0.001/-0 dimension. Is that the right way of dimensioning it?Last edited by programmer; 04-24-2019, 10:35 AM.
Originally posted by programmer View Post"You gave GX for both upper and lower." i gave it the +0.001/-0 dimension. Is that the right way of dimensioning it?
From the PC-DMIS help file:
The Size command supports the following modifiers that are defined in the ISO 14405-1 standard:
(LP) - Two-point size
(GG) - Least-squares association criterion
(GX) - Maximum inscribed association criterion
(GN) - Minimum circumscribed association criterion
(CC) - Circumference diameter (calculated size)
(CA) - Area diameter (calculated size)
(CV) - Volume diameter (calculated size)
(SX) - Maximum size
(SN) - Minimum size
(SA) - Average size
(SM) - Median size
(SD) - Mid-range size
(SR) - Range of sizes
(E) - Envelope requirement
ACS - Any cross section or sections
SCS - Specific fixed cross section or sections
- Likes 3
Originally posted by programmer View PostSo when I measure the actual 0.0632 ID do I use Least_SQr or MAX_INSC? The customer wants to see GX and GN reporting for the 0.0632 ID. Can you show an example? I only have the LEAST_SQR in there just to see the difference.
Code:SIZE4 =SIZE/ OUTPUT=BOTH, UNITS=MM, STANDARD: ISO 14405-1, TOLERANCE SPECIFICATION MODE: NOMINAL_WITH_DEVIATIONS, NOMINAL SIZE: 27, UPPER TOLERANCE: 0.1,GN,__, LOWER TOLERANCE: 0.1,GX,__, UPPER SIZE: 27, LOWER SIZE: 27, FEATURE: A3_2
Code:SIZE4 =SIZE/ OUTPUT=BOTH, UNITS=MM, STANDARD: ISO 14405-1, TOLERANCE SPECIFICATION MODE: NOMINAL_WITH_DEVIATIONS, NOMINAL SIZE: 27, UPPER TOLERANCE: 0.1,SX,__, LOWER TOLERANCE: 0.1,SN,__, UPPER SIZE: 27, LOWER SIZE: 27, FEATURE: A3_2
I'm not at the cmm to check, but I think an old bug reappeared : min circ cylinder and max inscr cylinder have the same vector, and the same form defect.
I believe that's a bug which had been fixed long time ago (not sure of it).
If you look at the text values, there are only 4 values at 0 ( I think there should be 5 !).
If someone here can check it, maybe a new thread is needed (I'm off the cmm for a week...)
Hello,
I`m measuring a setting ring diameter (nominal diam 69.994 mm) to check the touch-trigger probel lobbing error. I created an auto-circle...-
03-04-2019, 08:16 AM -
by VikingroovinHello,
I have tried in vain to use the help file. seems to be more or less a no help file. can I report min and max Diameter or am I stuck...-
02-24-2016, 10:29 AM -
by calbrittonI am measuring three circles on a part. I currently add these circles and report the average but I would also like to report the largest and smallest...
04-24-2015, 06:02 PM -
by gcunniffI'm having an issue with hole diameter in a plastic injection part. The hole is out of round approx. 0.020" I've run a scan of the diameter and...
04-18-2007, 10:55 AM -
by jakhillI am looking for the rule (standard) that would tell you when to report Max Inscribed diameter over Least Squared. I am reporting one way and the customer...
08-25-2016, 10:06 AM -
