The dimension value have wrong with actl data
  • The dimension value have wrong with actl data
    HI all,
    I have trouble with PCDMIS 2018R1/R2, 2019R1 that Have different value of ACTL and dimension,
    could you please help me with urgent!
    We cannot beliver report now!
    A.
    If you'd like to post some code, just copy it from PC-DMIS & paste it in here, with [code] tags. then you can amend whatever parts you need and give us only the information we need.
    B.
    It depends on what you're doing. Hows your alignment? What is this, a location? Is it relative to anything? Did you refresh the report? Did you edit the dimension, or restart PC-DMIS? Are you sure it's constructed correctly? Is this a verified program?
      Originally posted by InspectorJester View Post
      A.
      B.
      A, I dont know how to usse code, could you please advise
      B, This measure for sheet metal, I recall locall alignment. The report didnt update realy actual value from first point. Some point update corect, 90% is wrong.
        When you copy from the edit window of PCDMIS (the code you pictured) directly into your forum post, place it between the [CO DE][/CO DE] tags (without spaces between "CODE", there is a toolbar button for this as well.)
        From the looks of it, we will need more information/code to determine the problem.
        edit: I see a negative number under the -tol. From what you said your problem is, this isn't it but, it is not common to have a negative number in either + or - tol fields. These numbers are usually absolute values.
          Please refer program on below!
            Can someone open this and post the code? I haven't updated my version yet.
              There's too much text to post here, what specifically are you having an issue with?
                Any one help?
                  copy from your prg yours problematic dimensions and put copied text betwen this :
                  copied text
                    Here is the program from the zip file PART 1
                    STARTUP    =ALIGNMENT/START,RECALL:USE_PART_SETUP,LIST=YES
                                ALIGNMENT/END
                                MODE/DCC
                                PREHIT/4
                                RETRACT/4
                                WRISTSPEED/ 30
                                MOVESPEED/ 200
                                RMEAS/LEGACY (I,J,K, X,Y,Z)
                                FLY/ON
                                LOADPROBE/2_L
                                RECALL/ALIGNMENT,MCS
                    $$ NO,
                                /T1A90B90/
                                TIP/T1A0B0, SHANKIJK=0, -1, 0, ANGLE=-90
                                LOADPROBE/2_L
                    C2         =COMMENT/YESNO,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO,
                                OPERATOR:
                                ASSIGN/OPERATOR=C2
                                ASSIGN/REPORT_LOC="C:\Users\QUYTHUAN\Desktop\Test 2019"
                                ASSIGN/REPORT_NAME=1
                    $$ NO,
                                /T1A0B0/
                                RECALL/ALIGNMENT,EXTERNAL,A_BASE_QT
                                MOVE/POINT,NORMAL,<630,-900,800>
                    $$ NO,
                                START MEASURE FRONT DOOR P5
                    $$ NO,
                                FRONT DOOR ALIGNMENT
                    LH_LKWT901F=FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                                THEO/<630,-829.53,475>,<0,-0.99995,0.0099995>
                                ACTL/<632.174,-831.624,475.584>,<0.0019893,-0.999983,0.0054741>
                                TARG/<630,-829.53,475>,<0,-0.99995,0.0099995>
                                SNAP=NO
                                SHOW FEATURE PARAMETERS=NO
                                SHOW CONTACT PARAMETERS=YES
                                  AVOIDANCE MOVE=BOTH,DISTANCE=10
                                SHOW HITS=NO
                    DIM LOC135= LOCATION OF POINT LH_LKWT901F  UNITS=MM ,$
                    GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH  HALF ANGLE=NO
                    AX    NOMINAL       +TOL       -TOL       MEAS        DEV     OUTTOL
                    Y     -829.530      1.000      1.000   -831.632     -2.102      1.102 <--------
                    END OF DIMENSION LOC135
                    LH_LKWT907L=FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                                THEO/<592,-837,266>,<0,-1,0>,20
                                ACTL/<594.07,-837.087,266.578>,<-0.0404084,-0.9991223,-0.0110402>,20.758
                                TARG/<592,-837,266>,<0,-1,0>
                                START ANG=0,END ANG=0
                                ANGLE VEC=<1,0,0>
                                DIRECTION=CCW
                                  NUMHITS=5,DEPTH=2,PITCH=0
                                  SAMPLE METHOD=SAMPLE_HITS
                                  SAMPLE HITS=3,SPACER=5
                                  AVOIDANCE MOVE=BOTH,DISTANCE=30
                                SHOW HITS=NO
                    DIM LOC139= LOCATION OF CIRCLE LH_LKWT907L  UNITS=MM ,$
                    X      592.000      1.000      1.000    594.070      2.070      1.070 -------->
                    Z      266.000      1.000      1.000    266.578      0.578      0.000 -------#-
                    END OF DIMENSION LOC139
                    LH_LKWT903F=FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                                THEO/<630,-844.52,15>,<0,-0.99995,0.0099995>
                                ACTL/<631.946,-844.533,15.521>,<0.0019893,-0.999983,0.0054741>
                                TARG/<630,-844.52,15>,<0,-0.99995,0.0099995>
                                SNAP=NO
                                  AVOIDANCE MOVE=BOTH,DISTANCE=20
                                SHOW HITS=NO
                    DIM LOC138= LOCATION OF POINT LH_LKWT903F  UNITS=MM ,$
                    Y     -844.520      1.000      1.000   -844.540     -0.020      0.000 ----#----
                    END OF DIMENSION LOC138
                    LH_LKWT909L=FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                                THEO/<1625,-838.35,-78>,<0,-1,0>,16
                                ACTL/<1626.572,-839.538,-78.017>,<0.0131839,-0.9994059,0.0318426>,15.304
                                TARG/<1625,-838.35,-78>,<0,-1,0>
                                ANGLE VEC=<1,0,0>
                                DIRECTION=CCW
                                  SAMPLE HITS=3,SPACER=3
                                SHOW HITS=NO
                    DIM LOC137= LOCATION OF CIRCLE LH_LKWT909L  UNITS=MM ,$
                    Z      -78.000      1.000      1.000    -78.017     -0.017      0.000 ----#----
                    END OF DIMENSION LOC137
                    LH_LKWT905F_Y=FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                                THEO/<1750,-829.48,535>,<0,-0.999201,0.039968>
                                ACTL/<1752.025,-829.62,534.99>,<-0.000951,-0.9991249,0.0418161>
                                TARG/<1750,-829.48,535>,<0,-0.999201,0.039968>
                                SNAP=NO
                                SHOW HITS=NO
                    DIM LOC136= LOCATION OF POINT LH_LKWT905F_Y  UNITS=MM ,$
                    Y     -829.480      1.000      1.000   -829.625     -0.145      0.000 ---#-----
                    END OF DIMENSION LOC136
                                MOVE/POINT,NORMAL,<1750,-900,536.259>
                    A-FRONT DOOR=ALIGNMENT/START,RECALL:A_BASE_QT,LIST=YES
                                  ALIGNMENT/ITERATE
                                    PNT TARGET RAD=5,START LABEL=,FIXTURE TOL=0.05,ERROR LABEL=
                                    MEAS ALL FEAT=NO,LEVEL AXIS=YAXIS,ROTATE AXIS=ZAXIS,ORIGIN AXIS=XAXIS
                                  LEVEL=LH_LKWT901F,LH_LKWT903F,LH_LKWT905F_Y,,
                                  ROTATE=LH_LKWT907L,LH_LKWT909L,,
                                  ORIGIN=LH_LKWT907L,,
                                ALIGNMENT/END
                    $$ NO,
                      Part 2
                      front door measurement p5
                                  move/point,normal,<685.164,-900,649.23>
                      lh_lksw201f_xz=feat/contact/vector point/default,cartesian
                                  theo/<689.7,-782,651>,<-0.8256335,-0.4631603,-0.3221984>
                                  actl/<689.244,-782.254,650.826>,<-0.8256335,-0.4631603,-0.3221984>
                                  targ/<689.7,-782,651>,<-0.8256335,-0.4631603,-0.3221984>
                                  snap=no
                                  show feature parameters=no
                                  show contact parameters=yes
                                    avoidance move=both,distance=10
                                  show hits=no
                      lh_lksw201f_y=feat/contact/vector point/default,cartesian
                                  theo/<695,-782.4,657>,<-0.2007644,-0.7026753,0.6825988>
                                  actl/<694.888,-782.788,657.394>,<-0.2007644,-0.7026753,0.6825988>
                                  targ/<695,-782.4,657>,<-0.2007644,-0.7026753,0.6825988>
                                  snap=no
                                  show hits=no
                      lh_lksw203f_xz=feat/contact/vector point/default,cartesian
                                  theo/<719,-810,622.3>,<-0.776552,-0.5376129,-0.3285412>
                                  actl/<719.146,-809.9,622.365>,<-0.776552,-0.5376129,-0.3285412>
                                  targ/<719,-810,622.3>,<-0.776552,-0.5376129,-0.3285412>
                                  snap=no
                                  show hits=no
                      lh_lksw203f_y=feat/contact/vector point/default,cartesian
                                  theo/<725,-811.6,628>,<-0.140309,-0.8418541,0.5211478>
                                  actl/<725.121,-810.868,627.54>,<-0.140309,-0.8418541,0.5211478>
                                  targ/<725,-811.6,628>,<-0.140309,-0.8418541,0.5211478>
                                  snap=no
                                  show hits=no
                      lh_lkua201f_z=feat/contact/vector point/default,cartesian
                                  theo/<792,-790,657.9>,<0.5835707,-0.4527704,-0.6741248>
                                  actl/<791.439,-789.565,658.551>,<0.5835707,-0.4527704,-0.6741248>
                                  targ/<792,-790,657.9>,<0.5835707,-0.4527704,-0.6741248>
                                  snap=no
                                  show hits=no
                      lh_lkua201f_y=feat/contact/vector point/default,cartesian
                                  theo/<783,-796.2,670>,<-0.1603693,-0.8319156,0.5312232>
                                  actl/<783.131,-795.509,669.573>,<-0.1603693,-0.8319156,0.5312232>
                                  targ/<783,-796.2,670>,<-0.1603693,-0.8319156,0.5312232>
                                  snap=no
                                  show hits=no
                      lh_lkua205f_z=feat/contact/vector point/default,cartesian
                                  theo/<1303,-661,948.5>,<0.4302798,-0.5303448,-0.730475>
                                  actl/<1302.146,-659.949,949.959>,<0.4302798,-0.5303448,-0.730475>
                                  targ/<1303,-661,948.5>,<0.4302798,-0.5303448,-0.730475>
                                  snap=no
                                  show hits=no
                      lh_lkua205f_y=feat/contact/vector point/default,cartesian
                                  theo/<1300,-663.9,963>,<-0.1211874,-0.6968275,0.7069265>
                                  actl/<1300.173,-662.895,962.004>,<-0.1211874,-0.6968275,0.7069265>
                                  targ/<1300,-663.9,963>,<-0.1211874,-0.6968275,0.7069265>
                                  snap=no
                                  show hits=no
                      lh_lkua211f_z=feat/contact/vector point/default,cartesian
                                  theo/<1633,-611,1024.3>,<0.1199041,-0.6394886,-0.7593927>
                                  actl/<1632.876,-610.334,1025.089>,<0.1199041,-0.6394886,-0.7593927>
                                  targ/<1633,-611,1024.3>,<0.1199041,-0.6394886,-0.7593927>
                                  snap=no
                                  show hits=no
                      lh_lkua211f_y=feat/contact/vector point/default,cartesian
                                  theo/<1632,-612.8,1041>,<-0.0200512,-0.7218431,0.6917663>
                                  actl/<1632.049,-611.008,1039.238>,<-0.0200512,-0.7218431,0.6917663>
                                  targ/<1632,-612.8,1041>,<-0.0200512,-0.7218431,0.6917663>
                                  snap=no
                                  show hits=no
                        Part 3
                        dim loc1= location of point lh_lkua201f_z  units=mm ,$
                        graph=off  text=off  mult=10.00  output=both  half angle=no
                        ax    nominal       +tol       -tol       meas        dev     outtol
                        t        0.000      0.600      0.600     -0.963     -0.963      0.363 <--------
                        end of dimension loc1
                        dim loc2= location of point lh_lkua205f_z  units=mm ,$
                        t        0.000      0.600      0.600     -1.991     -1.991      1.391 <--------
                        end of dimension loc2
                                    workplane/xplus
                        dim dist1= 2d distance from point lh_lkua201f_z to point lh_lkua205f_z par to   zaxis,no_radius  units=mm,$
                        m      290.600      0.300      0.300    291.408      0.808      0.508 -------->
                        dim loc3= location of point lh_lkua211f_z  units=mm ,$
                        t        0.000      0.600      0.600     -1.040     -1.040      0.440 <--------
                        end of dimension loc3
                        dim dist2= 2d distance from point lh_lkua205f_y to point lh_lkua211f_z par to   zaxis,no_radius  units=mm,$
                        m       61.300      0.300      0.300     63.085      1.785      1.485 -------->
                                    workplane/zplus
                        dim loc4= location of point lh_lkua201f_y  units=mm ,$
                        t        0.000      0.600      0.600     -0.822     -0.822      0.222 <--------
                        end of dimension loc4
                        dim loc5= location of point lh_lkua205f_y  units=mm ,$
                        t        0.000      0.600      0.600     -1.425     -1.425      0.825 <--------
                        end of dimension loc5
                        dim loc6= location of point lh_lkua211f_y  units=mm ,$
                        t        0.000      0.600      0.600     -2.514     -2.514      1.914 <--------
                        end of dimension loc6
                        dim dist3= 2d distance from point lh_lkua201f_y to point lh_lkua205f_y par to   yaxis,no_radius  units=mm,$
                        m      132.300      0.300      0.300    132.615      0.315      0.015 -------->
                        dim dist4= 2d distance from point lh_lkua205f_y to point lh_lkua211f_y par to   yaxis,no_radius  units=mm,$
                        m       51.100      0.300      0.300     51.887      0.787      0.487 -------->
                                    move/point,normal,<1631.89,-800,1044.801>
                                    workplane/zplus
                        $$ no,
                                    complteted front door_p5
                        $$ yes,
                                    starting rear door_p4
                                    note: Re-use lkwt905f_y;lkwt907l; lkwt909l from front door
                                    recall/alignment,external,a_base_qt
                                    move/point,normal,<2894.423,-800,704.351>
                        lh_lkwt915f=feat/contact/vector point/default,cartesian
                                    theo/<2895,-773,693.27>,<-0.0502088,-0.2610858,0.964009>
                                    actl/<2897.047,-773.928,693.38>,<-0.0506424,-0.2592546,0.9644804>
                                    targ/<2895,-773,693.27>,<-0.0502088,-0.2610858,0.964009>
                                    snap=no
                                    show hits=no
                        dim loc140= location of point lh_lkwt915f  units=mm ,$
                        z      693.270      1.000      1.000    693.505      0.235      0.000 -----#---
                        end of dimension loc140
                                    move/point,normal,<2894.423,-920,704.351>
                        lh_lkwt913f=feat/contact/vector point/default,cartesian
                                    theo/<2715,-907.4,500>,<0.0200512,-0.9624574,0.2706911>
                                    actl/<2716.957,-908.515,500.324>,<0.0190901,-0.9619735,0.2724748>
                                    targ/<2715,-907.4,500>,<0.0200512,-0.9624574,0.2706911>
                                    snap=no
                                    show hits=no
                        dim loc141= location of point lh_lkwt913f  units=mm ,$
                        y     -907.400      1.000      1.000   -908.554     -1.154      0.154 <--------
                        end of dimension loc141
                                    move/point,normal,<1715,-900,15.803>
                        lh_lkwt911f_y=feat/contact/vector point/default,cartesian
                                    theo/<1715,-842.95,15>,<0,-0.997559,0.0698291>
                                    actl/<1717.113,-844.019,15.009>,<-0.0009553,-0.9974276,0.0716741>
                                    targ/<1715,-842.95,15>,<0,-0.997559,0.0698291>
                                    snap=no
                                    show hits=no
                        dim loc142= location of point lh_lkwt911f_y  units=mm ,$
                        y     -842.950      1.000      1.000   -844.012     -1.062      0.062 <--------
                        end of dimension loc142
                                    move/point,normal,<1715,-950,15.803>
                        a-rear door=alignment/start,recall:a_base_qt,list=yes
                                      alignment/iterate
                                        pnt target rad=5,start label=,fixture tol=0.05,error label=
                                        meas all feat=no,level axis=yaxis,rotate axis=zaxis,origin axis=xaxis
                                      level=lh_lkwt905f_y,lh_lkwt911f_y,lh_lkwt913f,,
                                      rotate=lh_lkwt909l,lh_lkwt915f,,
                                      origin=lh_lkwt907l,,
                                    alignment/end
                                    move/point,normal,<1900.23,-950,1025.866>
                        $$ no,
                                    functional measurement
                        lh_lkqa201f_z=feat/contact/vector point/default,cartesian
                                    theo/<1900,-596,1034.6>,<0.019995,-0.6498376,-0.7598101>
                                    actl/<1900.001,-595.992,1034.615>,<0.019995,-0.6498376,-0.7598101>
                                    targ/<1900,-596,1034.6>,<0.019995,-0.6498376,-0.7598101>
                                    snap=no
                                    show hits=no
                                    move/point,normal,<1900,-630,1055>
                        lh_lkqa201f_y=feat/contact/vector point/default,cartesian
                                    theo/<1900,-600,1056.58>,<0,-0.7690393,0.6392015>
                                    actl/<1900,-600.092,1056.694>,<0,-0.7690393,0.6392015>
                                    targ/<1900,-600,1056.58>,<0,-0.7690393,0.6392015>
                                    snap=no
                                    show hits=no
                        lh_lkqa203f_y=feat/contact/vector point/default,cartesian
                                    theo/<2265,-603,1043.06>,<0.0199432,-0.7777865,0.6282121>
                                    actl/<2264.985,-602.368,1042.569>,<0.0199432,-0.7777865,0.6282121>
                                    targ/<2265,-603,1043.06>,<0.0199432,-0.7777865,0.6282121>
                                    snap=no
                                    show hits=no
                                    move/point,normal,<2265,-630,1030>
                        lh_lkqa203f_z=feat/contact/vector point/default,cartesian
                                    theo/<2265,-598.5,1021.06>,<-0.0903941,-0.6628899,-0.7432402>
                                    actl/<2264.976,-598.662,1020.871>,<-0.0903941,-0.6628899,-0.7432402>
                                    targ/<2265,-598.5,1021.06>,<-0.0903941,-0.6628899,-0.7432402>
                                    snap=no
                                    show hits=no
                                    move/point,normal,<2263.961,-720,1012.517>
                        lh_lkqa205f_y=feat/contact/vector point/default,cartesian
                                    theo/<2885,-707.89,835>,<0.1007074,-0.8459425,0.5236787>
                                    actl/<2884.903,-707.075,834.498>,<0.1007074,-0.8459425,0.5236787>
                                    targ/<2885,-707.89,835>,<0.1007074,-0.8459425,0.5236787>
                                    snap=no
                                      avoidance move=both,distance=20
                                    show hits=no
                        lh_lkqa205f_z=feat/contact/vector point/default,cartesian
                                    theo/<2873.5,-700,818>,<-0.6676552,-0.5057994,-0.5462633>
                                    actl/<2873.105,-700.293,817.686>,<-0.6676552,-0.5057994,-0.5462633>
                                    targ/<2873.5,-700,818>,<-0.6676552,-0.5057994,-0.5462633>
                                    snap=no
                                    show hits=no
                                    move/point,normal,<2865.826,-750,811.721>
                                    move/point,normal,<2789.937,-900,630.821>
                          Part 4
                          lh_lkth201f_x=feat/contact/vector point/default,cartesian
                                      theo/<2798.36,-837,623>,<-0.7327935,0,0.6804511>
                                      actl/<2797.559,-837.001,623.732>,<-0.7327935,0,0.6804511>
                                      targ/<2798.36,-837,623>,<-0.7327935,0,0.6804511>
                                      snap=no
                                      show hits=no
                          lh_lkth201f_z y=feat/contact/vector point/default,cartesian
                                      theo/<2808,-845,623.79>,<0.0100641,-0.6441031,0.7648725>
                                      actl/<2808.001,-845.101,623.893>,<0.0100641,-0.6441031,0.7648725>
                                      targ/<2808,-845,623.79>,<0.0100641,-0.6441031,0.7648725>
                                      snap=no
                                      show hits=no
                          lh_lkth299f_x=feat/contact/vector point/default,cartesian
                                      theo/<2761.3,-875,580>,<-0.759962,0,0.6499675>
                                      actl/<2760.26,-874.997,580.892>,<-0.759962,0,0.6499675>
                                      targ/<2761.3,-875,580>,<-0.759962,0,0.6499675>
                                      snap=no
                                      show hits=no
                          lh_lkth299f_y=feat/contact/vector point/default,cartesian
                                      theo/<2785,-880.45,580>,<0,-0.9914883,0.1301954>
                                      actl/<2784.995,-880.569,580.014>,<0,-0.9914883,0.1301954>
                                      targ/<2785,-880.45,580>,<0,-0.9914883,0.1301954>
                                      snap=no
                                      show hits=no
                                      move/point,normal,<2594.598,-950,376.348>
                          lh_lkth203f_x=feat/contact/vector point/default,cartesian
                                      theo/<2604.18,-919,370>,<-0.83365,0,0.5522931>
                                      actl/<2602.738,-919.001,370.948>,<-0.83365,0,0.5522931>
                                      targ/<2604.18,-919,370>,<-0.83365,0,0.5522931>
                                      snap=no
                                      show hits=no
                                      move/point,normal,<2611.771,-950,365.688>
                          lh_lkth203f_y=feat/contact/vector point/default,cartesian
                                      theo/<2612,-925.73,365>,<-0.0199601,-0.998006,0.0598804>
                                      actl/<2611.992,-926.02,365.015>,<-0.0199601,-0.998006,0.0598804>
                                      targ/<2612,-925.73,365>,<-0.0199601,-0.998006,0.0598804>
                                      snap=no
                                      show hits=no
                                      move/point,normal,<2420,-950,54>
                          lh_lkth205f_x=feat/contact/vector point/default,cartesian
                                      theo/<2446.98,-904,54>,<-0.9325681,0,0.3609941>
                                      actl/<2445.561,-904.001,54.546>,<-0.9325681,0,0.3609941>
                                      targ/<2446.98,-904,54>,<-0.9325681,0,0.3609941>
                                      snap=no
                                      show hits=no
                          lh_lkth205f_y=feat/contact/vector point/default,cartesian
                                      theo/<2455,-911.48,50>,<-0.240072,-0.9702911,-0.030009>
                                      actl/<2454.827,-912.165,49.981>,<-0.240072,-0.9702911,-0.030009>
                                      targ/<2455,-911.48,50>,<-0.240072,-0.9702911,-0.030009>
                                      snap=no
                                      show hits=no
                          $$ yes,
                                      rear door p-4
                          dim loc7= location of point lh_lkwt901f  units=mm ,$
                          t        0.000      0.500      0.500      2.910      2.910      2.410 -------->
                          end of dimension loc7
                          dim loc8= location of point lh_lkwt903f  units=mm ,$
                          t        0.000      0.500      0.500     -0.023     -0.023      0.000 ----#----
                          end of dimension loc8
                          dim dist5= 2d distance from point lh_lkwt901f to point lh_lkwt903f par to   yaxis,no_radius  units=mm,$
                          m       14.990      0.300      0.300     12.058     -2.932      2.632 <--------
                          dim loc9= location of point lh_lkth201f_x  units=mm ,$
                          t        0.000      0.600      0.600      1.085      1.085      0.485 -------->
                          end of dimension loc9
                          dim loc10= location of point lh_lkth203f_x  units=mm ,$
                          t        0.000      0.600      0.600      1.725      1.725      1.125 -------->
                          end of dimension loc10
                          dim loc11= location of point lh_lkth205f_x  units=mm ,$
                          t        0.000      0.600      0.600      1.521      1.521      0.921 -------->
                          end of dimension loc11
                          dim loc12= location of point lh_lkth299f_x  units=mm ,$
                          t        0.000      0.600      0.600      1.370      1.370      0.770 -------->
                          end of dimension loc12
                            PART 5
                            DIM DIST6= 2D DISTANCE FROM POINT LH_LKTH201F_X TO POINT LH_LKTH203F_X PAR TO   XAXIS,NO_RADIUS  UNITS=MM,$
                            M      194.180      0.300      0.300    194.821      0.641      0.341 -------->
                            DIM DIST7= 2D DISTANCE FROM POINT LH_LKTH203F_X TO POINT LH_LKTH205F_X PAR TO   XAXIS,NO_RADIUS  UNITS=MM,$
                            M      157.200      0.300      0.300    157.177     -0.023      0.000 ----#----
                            DIM DIST8= 2D DISTANCE FROM POINT LH_LKTH205F_X TO POINT LH_LKTH299F_X PAR TO   XAXIS,NO_RADIUS  UNITS=MM,$
                            M      314.320      0.300      0.300    314.699      0.379      0.079 -------->
                            DIM LOC13= LOCATION OF POINT LH_LKTH201F_Z Y  UNITS=MM ,$
                            T        0.000      0.600      0.600      0.143      0.143      0.000 -----#---
                            DIM LOC14= LOCATION OF POINT LH_LKTH203F_Y  UNITS=MM ,$
                            T        0.000      0.600      0.600      0.291      0.291      0.000 ------#--
                            END OF DIMENSION LOC14
                            DIM LOC15= LOCATION OF POINT LH_LKTH205F_Y  UNITS=MM ,$
                            T        0.000      0.600      0.600      0.706      0.706      0.106 -------->
                            END OF DIMENSION LOC15
                            DIM LOC16= LOCATION OF POINT LH_LKTH299F_Y  UNITS=MM ,$
                            T        0.000      0.600      0.600      0.120      0.120      0.000 -----#---
                            END OF DIMENSION LOC16
                            DIM DIST9= 2D DISTANCE FROM POINT LH_LKTH201F_Z Y TO POINT LH_LKTH299F_Y PAR TO   YAXIS,NO_RADIUS  UNITS=MM,$
                            M       35.450      0.300      0.300     35.468      0.018      0.000 ----#----
                            DIM DIST10= 2D DISTANCE FROM POINT LH_LKTH299F_Y TO POINT LH_LKTH203F_Y PAR TO   YAXIS,NO_RADIUS  UNITS=MM,$
                            M       45.280      0.300      0.300     45.451      0.171      0.000 -------#-
                            DIM DIST11= 2D DISTANCE FROM POINT LH_LKTH203F_Y TO POINT LH_LKTH205F_Y PAR TO   YAXIS,NO_RADIUS  UNITS=MM,$
                            M       14.250      0.300      0.300     13.856     -0.394      0.094 <--------
                            $$ YES,
                                        FRAME REAR DOOR P-4
                            DIM LOC17= LOCATION OF POINT LH_LKQA201F_Z  UNITS=MM ,$
                            T        0.000      0.600      0.600     -0.016     -0.016      0.000 ----#----
                            END OF DIMENSION LOC17
                            DIM LOC18= LOCATION OF POINT LH_LKQA203F_Z  UNITS=MM ,$
                            T        0.000      0.600      0.600      0.250      0.250      0.000 ------#--
                            END OF DIMENSION LOC18
                            DIM LOC19= LOCATION OF POINT LH_LKQA205F_Z  UNITS=MM ,$
                            T        0.000      0.600      0.600      0.584      0.584      0.000 --------#
                            END OF DIMENSION LOC19
                                        WORKPLANE/XPLUS
                            DIM DIST12= 2D DISTANCE FROM POINT LH_LKQA201F_Z TO POINT LH_LKQA203F_Z PAR TO   ZAXIS,NO_RADIUS  UNITS=MM,$
                            M       13.540      0.300      0.300     13.743      0.203      0.000 -------#-
                            DIM DIST13= 2D DISTANCE FROM POINT LH_LKQA203F_Z TO POINT LH_LKQA205F_Z PAR TO   ZAXIS,NO_RADIUS  UNITS=MM,$
                            M      203.060      0.300      0.300    203.185      0.125      0.000 ------#--
                                        WORKPLANE/ZPLUS
                            DIM LOC20= LOCATION OF POINT LH_LKQA201F_Y  UNITS=MM ,$
                            END OF DIMENSION LOC20
                            DIM LOC21= LOCATION OF POINT LH_LKQA203F_Y  UNITS=MM ,$
                            T        0.000      0.600      0.600     -0.800     -0.800      0.200 <--------
                            END OF DIMENSION LOC21
                            DIM LOC22= LOCATION OF POINT LH_LKQA205F_Y  UNITS=MM ,$
                            T        0.000      0.600      0.600     -0.962     -0.962      0.362 <--------
                            END OF DIMENSION LOC22
                            DIM DIST14= 2D DISTANCE FROM POINT LH_LKQA201F_Y TO POINT LH_LKQA203F_Y PAR TO   YAXIS,NO_RADIUS  UNITS=MM,$
                            M        3.000      0.300      0.300      2.276     -0.724      0.424 <--------
                            DIM DIST15= 2D DISTANCE FROM POINT LH_LKQA203F_Y TO POINT LH_LKQA205F_Y PAR TO   YAXIS,NO_RADIUS  UNITS=MM,$
                            M      104.890      0.300      0.300    104.707     -0.183      0.000 -#-------
                            $$ NO,
                                        COMPLTETED FRONT DOOR_P4
                                        MOVE/POINT,NORMAL,<630,-1100,299.633>
                                        PRINT/REPORT,EXEC MODE=END,$
                                          TO_FILE=ON,OVERWRITE=C:\Users\QUYTHUAN\Desktop\Test 2019\SEDAN LOCAL_ALIGNMENT_SEDAN_LH_PARTIAL BUILD_test8.PDF,AUTO OPEN=OFF,$
                                          TO_PRINTER=OFF,COPIES=1,$
                                          TO_DMIS_REPORT=OFF,FILE_OPTION=INDEX,FILENAME=D:\RUNNING PRO\03-2019\20190326\SEDAN PARTIAL BUILD\LOCAL_ALIGNMENT_SEDAN_LH_REV02_SEDAN Spot weld body counting 4.dmo,$
                                          REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=YES,$
                                          TO_EXCEL=OFF,$
                              Hmmm, there's definitely something odd going on here.
                              I've not gone through it with a fine-toothed comb but it appears the issue only exists in the Y-axis.
                              Can you post a screen shot of the settings in the general tab of setup (F5 > Setup) .
                              I notice you have a RMEAS(LEGACY) command in there.
                              I can only speculate that there some combination of settings (Allow fins tuning of alignment / Treat theo values as if stored in part coordinates etc) that's having some impact.
                              Applications Engineer
                              Hexagon UK
