Optiv 443 Duel Z. My camera hit the Z+ limit. How do I get it off?
Limit switch
I don't know about optiv, but you should have a file like "constant.dat" that define the software limits lower than hardware limits (something like PSWLIM and MSWLIM).
In your case, the software limit is certainly highr than the hardware limit.
If you can't change those values by yourself (right access), you will have to call Hexagon.
Jefman has the more permanent solution.
But if you need to get it going right away, you'll have to pop off the cover and unscrew the limit switch to "unlock" it so you can move it down. Just remember to make some marks so you can put the switch back to the same spot!
Are you able to turn on Manual Backstep (right click the beating heart>manual backstep) and get it to move?
Otherwise, there was an expert in here a few years ago that experienced the same problem on our Optiv 443.
He just sort of pulled really hard until it moved... I don't know if this is recommended, but it didn't hurt anything
by glancyOn one of my programs there is a point that is very close to the table maybe about 60-70 mm off the table. Every time I go to take this point I get a...
11-06-2017, 01:55 PM -
by DrBudmanDoes anyone know how to change the over travel limit in PC-Dmis? I need about .05" more travel to measure a certain feature.
Than...-
05-12-2006, 04:51 PM -
by Wes CiscoDoes anyone know where I change the lower z-axis limit so I bring the ram down closer to table? TIA
01-17-2008, 03:23 PM -
by Scott MeyerI work on two of the same MicroExcel PFX CMM's, one has a total limit in the y travel of 16.75 and the other has 16.686 of travel. How can I change the...
03-06-2013, 10:53 AM -
by rangerboat72We relocated our CMM's a couple of weeks ago and had them calibrated last week by Hexagon. We had no problems until today when we were editing a program...
05-11-2010, 01:32 PM -
