Good morning, I am having trouble inserting a probe file from another computer into the one I am using now. Can someone help me with that? Thank you in advance!
Inserting Probe File
IF you are trying to put a probe from one Demon install to another...try this:
1) COPY the XXXXXX.PRB file from the existing Demon install's Probe folder (find that path)
2) PASTE the XXXXXX.PRB file into the new home Demon install's Probe folder. (dump it in the probe folder named per the Demon's PATH)
Then that probe should be good-to-go in the probe list.
If it's a custom one in usrprobe.dat, then copy/paste that file. usually the path to that is:
C:\ProgramData\Hexagon\PC-DMIS\20XX Rx\usrprobe.datLast edited by sealevel; 04-20-2019, 10:01 AM.
- Likes 1
by DarrollhGood morning,
How do I go about inserting a probe file? Thank you in advance.-
04-13-2019, 10:30 AM -
by ginnbobHow do I add a probe file to the drop down window. I want to copy a probe file from one machine to another. how can this be done?
06-09-2021, 09:44 AM -
by Steve RHi all, I received the probe file for a disc probe I purchased in a .txt format. I copied and pasted it to my 2017R1 folder on the C drive. I then converted...
04-05-2018, 10:03 PM -
by Steve RHi all I purchased a custom disc probe with a txt. Probe file. I converted the the .txt to .DAT file and moved it to the PC DMIS 2017R folder under program...
04-19-2018, 09:54 PM -
hey guys, i'm new to the forum so if this question has been asked a ton of times i appologize. my question is we are running a program on a different...
01-14-2009, 08:23 AM -
