Hello all,
I am pretty green with the CMM but I am learning reasonably well thanks to this forum, I have no training at all so any wisdom will be appreciated. I however have a problem that persists across a few of the programs I have run, and am trying to understand what I am doing wrong.
The scenario is pretty much the same in all instances, I start the machine (Hexagon 7.10.7 sf) home it out, touch off sphere with the master probe open my program, and touch off sphere with all probes used in program. So I am assuming the machine to be okay.
I do the manual alignment (plane, circle, and rotate) as similar to the graphics as possible (most of the time). Then when DCC takes over the machine seems to be "looking" for the part about a quarter of an inch off of the actual position (as if the part had shifted towards me and to the left (seven o'clock). This has happened in a couple of programs before and I had gone in to change hit points manually and got around the problem. Lately though the programs are proven, and have run before and my supervisor, who wrote them ( had level one training) nor I understand the problem. Code is attached.
Thanks in advance for the reviews and replies.
PART NAME : 1594137 No Model
REV NUMBER : 4
SER NUMBER : 344
STATS COUNT : 1
ALIGNMENT/END
MODE/MANUAL
RETRACT/0.02
MOVESPEED/ 300
TOUCHSPEED/ 3
LOADPROBE/3X40-SF
MODE/MANUAL
PLN1 =FEAT/PLANE,CARTESIAN,TRIANGLE
THEO/<12.1562,15.4135,-21.7284>,<-0.0033208,-0.0024816,0.9999914>
ACTL/<12.2283,12.2745,-21.728>,<-0.0016677,-0.0036723,0.9999919>
MEAS/PLANE,4
HIT/BASIC,NORMAL,<11.3127,16.6557,-21.7281>,<-0.0033208,-0.0024816,0.9999914>,<11.222,13.3956,-21.7256>,USE THEO=YES
HIT/BASIC,NORMAL,<13.5593,16.0559,-21.7222>,<-0.0033208,-0.0024816,0.9999914>,<13.2275,13.3956,-21.7222>,USE THEO=YES
HIT/BASIC,NORMAL,<12.8824,14.1614,-21.729>,<-0.0033208,-0.0024816,0.9999914>,<13.2275,11.1534,-21.7305>,USE THEO=YES
HIT/BASIC,NORMAL,<10.8705,14.781,-21.7343>,<-0.0033208,-0.0024816,0.9999914>,<11.2364,11.1534,-21.7337>,USE THEO=YES
ENDMEAS/
CIR1 =FEAT/CIRCLE,CARTESIAN,IN,LEAST_SQR
THEO/<12.2105,15.4561,0>,<0,0,1>,2.1263
ACTL/<12.215,12.2871,0>,<0,0,1>,2.1254
MEAS/CIRCLE,4,ZPLUS
HIT/BASIC,NORMAL,<11.1787,15.7118,-22.1427>,<0.9706364,-0.2405515,0>,<11.1532,12.336,-22.1854>,USE THEO=YES
HIT/BASIC,NORMAL,<12.2507,16.5186,-22.1427>,<-0.0377986,-0.9992854,0>,<12.2127,13.3496,-22.1854>,USE THEO=YES
HIT/BASIC,NORMAL,<13.207,15.8266,-22.1427>,<-0.9373122,-0.3484907,0>,<13.2307,11.9739,-22.2041>,USE THEO=YES
HIT/BASIC,NORMAL,<12.275,14.3949,-22.1427>,<-0.0606051,0.9981618,0>,<12.1016,11.2306,-22.3056>,USE THEO=YES
ENDMEAS/
LIN1 =FEAT/LINE,CARTESIAN,UNBOUNDED
THEO/<12.2505,12.6124,0>,<-0.0139052,0.9999033,0>
ACTL/<12.2275,10.2014,0>,<0.0066369,-0.999978,0>
MEAS/LINE,2,ZPLUS
HIT/BASIC,NORMAL,<12.2505,12.6124,-22.5343>,<0.9999033,0.0139052,0>,<12.2275,10.2014,-22.3832>,USE THEO=YES
HIT/BASIC,NORMAL,<12.24,13.3645,-22.5343>,<0.9999033,0.0139052,0>,<12.2314,9.6101,-22.3832>,USE THEO=YES
ENDMEAS/
ALIGNMENT/LEVEL,ZPLUS,PLN1
ALIGNMENT/TRANS,ZAXIS,PLN1
ALIGNMENT/ROTATE,YPLUS,TO,LIN1,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,CIR1
ALIGNMENT/TRANS,YAXIS,CIR1
ALIGNMENT/END
MODE/DCC
MOVE/POINT,NORMAL,<-0.0253,-0.2568,1.0672>
TOP OF PART=FEAT/PLANE,CARTESIAN,TRIANGLE
THEO/<-0.0925,-0.2772,0.0001>,<0.0000766,-0.0000904,1>
ACTL/<-0.0926,-0.2793,-0.0316>,<0.0015058,0.0388277,0.9992448>
MEAS/PLANE,4
HIT/BASIC,NORMAL,<-1.5565,-0.238,0.0001>,<0.0000766,-0.0000904,1>,<-1.5565,-0.2401,-0.0118>,USE THEO=YES
HIT/BASIC,NORMAL,<0.4951,1.246,0.0002>,<0.0000766,-0.0000904,1>,<0.495,1.2438,-0.1044>,USE THEO=YES
HIT/BASIC,NORMAL,<1.2997,-0.71,-0.0001>,<0.0000766,-0.0000904,1>,<1.2995,-0.712,0>,USE THEO=YES
HIT/BASIC,NORMAL,<-0.6083,-1.4069,0>,<0.0000766,-0.0000904,1>,<-0.6084,-1.409,-0.01>,USE THEO=YES
ENDMEAS/
MOVE/POINT,NORMAL,<0.0971,-0.1843,0.6131>
3.126 I.D. =FEAT/CYLINDER,CARTESIAN,IN,LEAST_SQR
THEO/<-0.0767,-0.0523,-0.6269>,<0.0004858,0.0004504,-0.9999998>,2.1258,0.4275
ACTL/<0.0201,-3.0883,-0.639>,<-0.0006023,0.0009036,-0.9999994>,2.1254,0.4264
MEAS/CYLINDER,12
HIT/BASIC,NORMAL,<-1.1394,-0.0192,-0.4147>,<0.9995108,-0.0312709,0.0004714>,<-1.1748,-0.0182,-0.4148>,USE THEO=YES
HIT/BASIC,NORMAL,<-0.5669,0.8903,-0.4185>,<0.4612595,-0.8872652,-0.0001756>,<-0.5908,0.9376,-0.4186>,USE THEO=YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,<0.7747,0.5848,-0.422>,<-0.8006229,-0.5991682,-0.0006588>,<0.9113,0.6868,-0.422>,USE THEO=YES
HIT/BASIC,NORMAL,<0.6493,-0.8284,-0.4184>,<-0.683213,0.7302191,-0.000003>,<0.6264,-0.8026,-0.4186>,USE THEO=YES
HIT/BASIC,NORMAL,<-0.1547,-1.1124,-0.4153>,<0.0732709,0.997312,0.0004848>,<0.0853,-2.1465,-0.4256>,USE THEO=YES
HIT/BASIC,NORMAL,<-0.8711,-0.7592,-0.4138>,<0.7470887,0.664724,0.0006623>,<0.7232,-2.4567,-0.4256>,USE THEO=YES
HIT/BASIC,NORMAL,<-0.9541,-0.6521,-0.8323>,<0.8255553,0.5643209,0.0006552>,<0.7973,-2.5505,-0.8449>,USE THEO=YES
HIT/BASIC,NORMAL,<-1.0968,0.2452,-0.8339>,<0.96003,-0.2798968,0.0003403>,<0.9293,-3.346,-0.8472>,USE THEO=YES
HIT/BASIC,NORMAL,<0.3667,0.9137,-0.84>,<-0.4171141,-0.9088539,-0.000612>,<-0.3651,-3.9512,-0.8527>,USE THEO=YES
HIT/BASIC,NORMAL,<0.7624,-0.7046,-0.8376>,<-0.7894473,0.6138184,-0.000107>,<-0.7303,-2.513,-0.8474>,USE THEO=YES
HIT/BASIC,NORMAL,<0.0834,-1.1029,-0.8345>,<-0.1504897,0.9886115,0.0003722>,<-0.127,-2.1548,-0.8447>,USE THEO=YES
HIT/BASIC,NORMAL,<-0.6765,-0.9298,-0.8325>,<0.5643336,0.8255466,0.000646>,<0.5492,-2.3053,-0.8437>,USE THEO=YES
ENDMEAS/
MOVE/POINT,NORMAL,<-0.015,0.0452,0.7625>
MOVE/POINT,NORMAL,<0.4103,-2.5905,0.7675>
FRONT OF LEFT EAR=FEAT/LINE,CARTESIAN,UNBOUNDED
THEO/<-0.0748,-2.9494,0>,<0.0000055,1,0>
ACTL/<-0.0012,-0.193,-0.0083>,<0.0079336,-0.9999678,-0.0012147>
MEAS/LINE,2,ZPLUS
HIT/BASIC,NORMAL,<-0.0748,-2.9494,-0.8484>,<1,-0.0000055,0>,<-0.1203,-0.1924,-0.8565>,USE THEO=YES
HIT/BASIC,NORMAL,<-0.0748,-2.1109,-0.8504>,<1,-0.0000055,0>,<-0.1137,-1.0309,-0.8594>,USE THEO=YES
ENDMEAS/
A5 =ALIGNMENT/START,RECALL:A1,LIST=YES
ALIGNMENT/LEVEL,ZPLUS,TOP OF PART
ALIGNMENT/TRANS,ZAXIS,TOP OF PART
ALIGNMENT/ROTATE,YPLUS,TO,FRONT OF LEFT EAR,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,3.126 I.D.
ALIGNMENT/TRANS,YAXIS,3.126 I.D.
ALIGNMENT/END
REV NUMBER : 4
SER NUMBER : 344
STATS COUNT : 1
ALIGNMENT/END
MODE/MANUAL
RETRACT/0.02
MOVESPEED/ 300
TOUCHSPEED/ 3
LOADPROBE/3X40-SF
MODE/MANUAL
MEAS/PLANE,4
ENDMEAS/
MEAS/CIRCLE,4,ZPLUS
ENDMEAS/
MEAS/LINE,2,ZPLUS
ENDMEAS/
ALIGNMENT/END
MODE/DCC
MEAS/PLANE,4
ENDMEAS/
MEAS/CYLINDER,12
MOVE/CIRCULAR
ENDMEAS/
MEAS/LINE,2,ZPLUS
ENDMEAS/
ALIGNMENT/END
