http://software.hexagonmi.com/public...18_R2/SP6/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Versions/Release/
Maybe some problems on install, look here :
•PCD-145903 -
Fixed an issue where PC-DMIS was not able to generate a
Linear Closed scan path if there were holes in the path.
•PCD-146517 -
Fixed an issue that incorrectly removed feature labels from a
SNAPSHOTcommand that was edited.
•PCD-147121 -
Fixed an issue where the Pointcloud Point Colormap showed
or hid the points and text based on whether you marked the
Always visible check box on the OpenGL tab in the
CAD and Graphic Setup dialog box.
When you clear the Always visible check box, the Point Colormap points and text only appear if they appear in the current view.
•PCD-147444 -
Fixed an issue for Pointcloud Colormaps where the tolerances
were not set properly before computation of the colormap annotation
deviations when "Groups" were defined.
•PCD-149791 -
Updated to Release version 2.2 of Edge Client.
•PCD-150141 -
Fixed an issue of Quick Scan where a TTP probe created a
defined scan. Now, Quick Scan with a TTP probe creates a Normal execution mode scan.
•PCD-150803 -
Fixed an issue where the dimension color scale Show colors in
two directions option was automatically marked for pointcloud colormaps:
•When you enter a +Tol and zero in -
Tol in the colormap dialog box, the Show colors in two directions option is cleared in the Dimension Color Scale. The scale shows the colors from 0 to the +Tol value.
•When you enter a positive a nd negative tolerance in the colormap
dialog box, the dimension color scale shows in two directions. This is
because you entered the tolerances in two directions.
•PCD-150885 -
Fixed an issue where the Auto Wrist dialog box did not appear
and the CAD transformation matrix had to be a non-identity matrix to enter the failure state.
•PCD-150964 -
Corrected an issue where, in some cases, laser auto features
were not evaluated correctly when they were re-executed.
•PCD-150993 -
Fixed an issue in the Point Nominal Deviation dialog box
when there was a part setup transformation. The vectors drawn in the
Graphic Display window were disconnected from the CAD part.
•PCD-151095 -
Fixed an issue where if you switched the Part Model off and
then on didn't allow surface selection.
•PCD-151911 and PCD-158633 -
Fixed an issue where PC-DMIS prevented the polar coordinate axis from appearing in the summary label of the Xact Measure position.
•PCD-152016 -
Made improvements to colormap so that it relates better to
the selected surfaces.
•PCD-154084 -
Fixed an issue where the selection of the Pointcloud Colormap
did not remember the Use Dimension Color Scale option.
•PCD-155564 -
Fixed an issue where the offset value did not appear in the
Line Offsets dialog box when F9 was pressed on the command.
•PCD-155604 -
Fixed the feature highlighting in the Graphic Display window
when you edit XactMeasure dimensions in the XactMeasure GD&T
dialog box.
•PCD-156823 -
Fixed a migration issue from PC-DMIS version 2012 that caused
the loss of the diametric zone modifier in some XactMeasure dimensions.
•PCD-157142 -
Fixed an issue where the display of adaptive scan child
features are seen when you edit in the legacy dimension dialog box.
•PCD-157154 -
Removed the Workplane option from the Nominals tab in the XactMeasure GD&T dialog box.
•PCD-157396 -
Fixed an issue where incorrect conversion happened in the
Laser feature dialog boxes. This used to happen when you inserted standard deviation multiplier values for measurement routines in the Inch unit.
•PCD-158727 -
Fixed an issue where continuous scanning did not work when
you used an AT901 Tracker.
•PCD-158837 -
Fixed an issue where a cylinder could be solved as inner when
it was actually an outer cylinder.
•PCD-158842 -
Fixed an issue where a DCC command could be added to a
measurement routine while in Protected Mode.
•PCD-159401 -
Fixed an issue where the menu options were disabled after
you canceled the creation of FCF from grouped text box mode.
•PCD-160894 -
Fixed an issue where Vision Auto Features, such as circles and
lines with manual targets, had the crosshair shrink and disappear as the rotary angle went to 90 degrees.
•PCD-161285 -
Fixed an issue where measured features could be added to a
measurement routine that ran in Protected Mode (or Inspect) after you took hits and pressed the Done button on the jog box.
•PCD-161286 -
Fixed an issue where tip changes could be added to a
measurement routine that ran in Protected Mode (or Inspect) through
machine usage.
•PCD-161412 -
Fixed a crash that occurred when you clicked the Measure button in the Probe Utilities dialog box for the calibration of a CMS probe.
This issue occurred only in Online mode with FDC dual-arm controls and the probe was marked for Arm2.
•PCD-161655 -
Fixed an issue where if you pressed the stop button after a
collision on arm2, it was not possible to continue the execution.
•PCD-162469 -
Fixed an issue where I++ server didn't report the X and I values
for PtMeas.
•PCD-162476 -
Fixed a crash that occurred after you deleted a work plane and
updated all dimensions.
•PCD-162569 -
Fixed an issue where Technology Server 1.5 ignored the prehit
and retract properties for scanning. Now, you need to set the retract
properties in DCC mode before scanning, similar to Manual mode.
•Changes were made to improve the user experience based on feedback collected from recent releases.
