Hyper reports are not very well documented. They were 'replaced' by Forms in later versions of PC DMIS. I have not seen much difference between the two. Help files will get you somewhat started. What are you trying to do that may require a hyper report? I use them to document fixture setups for our flexible fixturing. I have also seen them used as a front end control. I've done a little bit with front end control but I'm no expert and it has been a while since I last did anything along those lines.
